1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CAJ bug?
To: <[email protected]>
Date: Fri, 19 Feb 2010 16:21:25 -0500
It seems that I need a ctxt.flushIo() after creating the monitor (thanks Geoff!). Can we add this to the JavaDocs?
   * Adds a monitor to this Channel. The monitor is guaranteed to start working
   * only after the next call to {@link #flushIo()}.
Thanks!
Gabriele
From: [email protected] [mailto:[email protected]] On Behalf Of Carcassi, Gabriele
Sent: Friday, February 19, 2010 11:07 AM
To: [email protected]
Subject: CAJ bug?
Hi all,
I have found something that looks like a bug in CAJ. If monitors are not registered right after the creation of the Channel, they don’t get notified at all. Here is a test case:
public class CAJBugTest {
    public static void main(String[] args) throws Exception {
        JCALibrary jca = JCALibrary.getInstance();
        Context ctxt = jca.createContext(JCALibrary.CHANNEL_ACCESS_JAVA);
        Channel ch = ctxt.createChannel("pvk01");
        //ctxt.pendIO(1.0);
        //Thread.sleep(1000);
        ch.addMonitor(DBRType.DOUBLE, 1, Monitor.VALUE, new MonitorListener() {
            @Override
            public void monitorChanged(MonitorEvent ev) {
                System.out.println("1 -> " + ev.getDBR().getValue());
        Channel ch2 = ctxt.createChannel("pvk01");
        ch2.addMonitor(DBRType.DOUBLE, 1, Monitor.VALUE, new MonitorListener() {
            @Override
                System.out.println("2 -> " + ev.getDBR().getValue());
        Thread.sleep(5000);
        ch.destroy();
        ch2.destroy();
        ctxt.destroy();
With the comments, this will work and show updates for the first and the second monitor. If the Sleep or pendIO calls are uncommented, all the subsequent monitor are not being notified. So, for example, if you remove the second sleep, you would see the notifications for the first monitor but not the second.
The problem is that this more or less defies the purpose of having CAJ caching and managing the channels and monitors for me… :-/
I am using CAJ 1.1.5b, JCA 2.3.2 on a Windows machine. Any thoughts?
Gabriele
CAJ bug? Carcassi, Gabriele
Prev: RE: Asyn port locking matthew.pearson
Next: Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version Ramu Denduluri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CAJ bug? Carcassi, Gabriele
Next: Asyn port locking ronaldo.mercado
