I was trying to compile Epics base 3.14.9 on 64 bit Fedora 11operating system and got compilation errors as follows: Installing library ../../../lib/linux-x86_64/libCom.a /usr/bin/ranlib ../../../lib/linux-x86_64/libCom.a /usr/bin/g++ -o libCom.so.3.14 -shared bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLib.o devLibOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o -lpthread -lreadline -lcurses -lm -lrt -lgcc /usr/bin/ld: /usr/lib/gcc/x86_64-redhat-linux/4.4.1/libstdc++.a(stdexcept.o): relocation R_X86_64_32S against `vtable for std::runtime_error' can not be used when making a shared object; recompile with -fPIC /usr/lib/gcc/x86_64-redhat-linux/4.4.1/libstdc++.a: could not read symbols: Bad value collect2: ld returned 1 exit status make[3]: *** [libCom.so.3.14] Error 1 make[3]: Leaving directory `/usr/local/src/epics-base-3.14.9-20100222_141103/src/libCom/O.linux-x86_64' make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory `/usr/local/src/epics-base-3.14.9-20100222_141103/src/libCom' make[1]: *** [libCom.install] Error 2 make[1]: Leaving directory `/usr/local/src/epics-base-3.14.9-20100222_141103/src' make: *** [src.install] Error 2 Could anybody please help me in fixing the errors. Regards, Ramu
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
