1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fwd: Sequencer bug?
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Date: Thu, 25 Feb 2010 12:28:30 -0600
I think every one of my state programs does pvPut and monitors on the
same PV.  Generally they do the following:
- Put a monitor and an event flag on a PV which is a bo or busy record
int     build;       assign build        to "{P}{R}Build.VAL";
evflag buildMon;       sync build        buildMon;
- Have a when clause like the following:
  when(efTestAndClear(buildMon) && (build==1)) {
        } state build
 - Set boVal back 0 to, do a pvPut
   /* Clear build command, post.  This is a "busy" record, don't want
    * to do this until build is complete. */
     build=0;
     pvPut(build);
The check for build=1 is needed because the event will also fire as a
result of the pvPut of the boVal back to 0.  That behaviour actually
changed in some version of the sequencer several years ago (previously I
could avoid the event flag being set as a result of the pvPut in the SNL
program).
I don't see anything wrong with the above logic, and I hope I don't a
bunch a warnings in a new version of the sequencer.  Is the problem that
was recently discussed limited to the case of multiple state sets
monitoring the same PV?
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Thursday, February 25, 2010 12:02 PM
To: [email protected]
Subject: Re: Fwd: Sequencer bug?
On Thursday 25 February 2010 07:43:51 Benjamin Franksen wrote:
> It remains to draw practical conclusions for how to avoid such race
> conditions in SNL code. Should we generally be wary of pvPut and
monitor to
> the same state variable?
That is certainly my recommendation, since doing so avoids having to
think
through the possible consequences for the state program.  Thanks for
posting
your detailed analysis, I think it shows that the issue is a very subtle
one.
When I've suggested not doing that in the past some people have said
that they
use the technique without problems, but I suspect that they could still
suffer
from it under some circumstances, they just haven't seen it /yet/ (or
maybe
their application doesn't fail spectacularly when it happens).
> Could the compiler warn us about that? Or is this too restrictive?
If someone wants to develop the code to add that as a warning I would be
in
favour of merging it.  I suspect that it wouldn't be too hard to do,
you'd do
the check whenever you process a pvPut() call (but I'm not a compiler
writer
so I could be wrong about the difficulty).  As long as it's a warning I
don't
think it would be too restrictive (C and C++ compilers have a long
history of
adding warnings as the developers discover more common anti-patterns).
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: Fwd: Sequencer bug? Mark Rivers
Re: Fwd: Sequencer bug? Benjamin Franksen
Re: Sequencer bug? Benjamin Franksen
Re: Fwd: Sequencer bug? Andrew Johnson
Prev: Re: Fwd: Sequencer bug? Andrew Johnson
Next: RE: Fwd: Sequencer bug? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
