1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IP asyn timeout connection
To: [email protected]
Date: Thu, 11 Mar 2010 10:09:25 -0600
Hi Mark,
On Thursday 11 March 2010 08:51:36 Mark Rivers wrote:
> One way to avoid this is to always restart your vxWorks IOC with the
> "reboot" command.  That will cause the EPICS exit handlers to be called.
> Recent versions of asyn install EPICS exit handlers which will cleanly
> close all TCP sockets, and EPICS CA also closes things cleanly.  Even if
> you need to power off the vxWorks system, you should first type "reboot",
> then power it off.  This will close the sockets cleanly.
Actually this will only work if you have a specific modification to your
vxWorks BSP which ensures that the epicsAtExit() handlers get called before
the network shuts down.  Note that a Control-X reboot will also cause these to
run.
The patch requires registering a rebootHook() early in the BSP startup process
before the network is initialized.  I described it in the tech-talk message
here: http://www.aps.anl.gov/epics/tech-talk/2005/msg00004.php
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: IP asyn timeout connection Mark Rivers
Prev: RE: IP asyn timeout connection Mark Rivers
Next: RE: IP asyn timeout connection Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
