Hi Dominique,
I was thinking about this some more, and realized I may have
misunderstood your question.
When you say:
> At each time there could be a few modbus tcp devices that
> are not available during the vme startup.
Do you mean that they are not available for good reason, like they are
powered off, disconnected from the network, etc.? And that the problem
is that it takes a long time for the driver to time out trying to reach
them? If that is what you meant, then that is a separate problem, which
I confess I have not paid much attention to this in the past, because I
have assumed that the devices must be available for the IOC to function
correctly.
Let me know if this is what you meant and I will look into it and get
back to you.
-----Original Message-----
From: Dominique Touchard [mailto:[email protected]]
Sent: Thursday, March 11, 2010 8:06 AM
To: Mark Rivers
Subject: IP asyn timeout connection
Hi Mark,
we are using the modbus tcp (thanks again for your software) to control
a few dozen of devices from an EPICS vme crate. We are testing now our
configuration, and starting often the vme crate to change our test
configuration. At each time there could be a few modbus tcp devices that
There are a lot of waste time to wait for timeout connections during the
drvMobusAsynConfigure command.( I suppose) (for example, we are testing
now 34 devices which owns 4 modbus functions, one global read and three
discret writes. In this case, the startup could spend half one hour
without any acces to the IOC)
I don't find where we can set the timeout for the first connection try.
Any help would be appreciated.
Thanks again.
Dominique Touchard.
- Re: IP asyn timeout connection Dominique Touchard
Re: IP asyn timeout connection Andrew Johnson
Re: Building EPICS for multiple Linux distributions Dirk Zimoch
<2010>
2025
2026
<2010>
2025
2026
