1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building EPICS for multiple Linux distributions
To: John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 11 Mar 2010 17:43:50 +0100
John Dobbins wrote:
I was wondering if anyone can suggest an approach for building EPICS on multiple linux distributions (which may have different kernel versions, compiler versions, etc.)
Does one define new architectures linux-x86-distribution_a linux-x86-distribution_b?
John Dobbins
Lab for Elementary Particle Physics
Cornell University
Hi John,
We build EPICS on multiple Linux versions, e.g Scientific Linux 3 and Scientific Linux 5. I have defined new architectures as you suggested. I used the names SL3-x86 and SL5-x86. The advantage of this approach is that different architectures are installed into different sub-directories. So code cannot get mixed up even if it is on a network drive.
I have created the configure files CONFIG.Common.SL3-x86, CONFIG.SL3-x86.Common, CONFIG.SL3-x86.SL3-x86, and CONFIG_SITE.SL3-x86.Common which basically just include their "linux-x86" analogon:
> cat CONFIG.Common.SL3-x86
# Include definitions common to linux targets
include $(CONFIG)/os/CONFIG.Common.linux-x86
> cat CONFIG.SL3-x86.Common
#CONFIG.$(EPICS_HOST_ARCH).Common is required by build system
#Include definitions common to linux hosts
include $(CONFIG)/os/CONFIG.linux-x86.Common
> cat CONFIG.SL3-x86.SL3-x86
# Include common linux definitions
include $(CONFIG)/os/CONFIG.linux-x86.linux-x86
> cat CONFIG_SITE.SL3-x86.Common
include $(CONFIG)/os/CONFIG_SITE.linux-x86.Common
The same for all other Linux architectures.
Don't forget to set EPICS_HOST_ARCH everywhere correctly so that EPICS Makefiles build the correct code. We set it for each system in a script in /etc/profile.d/.
I have very good experiences with this approach. Unfortunately, I did not succeed to "cross compile" e.g. SL3 on a SL5 host. That means every code has to be compiled separately on each operating system version.
Andrew mentioned that a different kernel does not require to rebuild the application code. But often a new Linux version comes with a new compiler version. And gcc tends to change things (especially C++) between versions. (Even with the same major release). I can run SL3 compiled code on SL5 but running SL5 compiled code on SL3 crashes with a floating point exception.
So it is safest to compile separately whenever gcc and/or glibc versions change.
Best regards,
Dirk
Re: Building EPICS for multiple Linux distributions Rod Nussbaumer
Building EPICS for multiple Linux distributions John Dobbins
Prev: RE: IP asyn timeout connection Mark Rivers
Next: Re: 2 MAXv problems Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building EPICS for multiple Linux distributions Steven M. Hartman
Next: Re: Building EPICS for multiple Linux distributions Rod Nussbaumer
