1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Tektronic Scope DPO7254 over VXI-11 crashes IOC
To: [email protected]
Date: Wed, 17 Mar 2010 11:31:07 +0100
this is something for the experts.
I'm trying to talk to the mentioned scope via asyn/stream and get mysterious
crashes the first time the IOC tries to communicate over the link. Below is
a trace of the IOC shell up to the crash. I am using the latest and greatest
versions of everything except EPICS base: base-3.14.8.2, asyn-4.11a
(supposedly the last version that works with base-3.14.8), StreamDevice-2-
snapshot20081007. The crash happens on the latest ubuntu version as well as
on a debian stable system. I should point out that with the exact same setup
I can talk fine with e.g. a GPIB controller.
I ran a debugger over the produced core file but I could not find any
indication what went wrong. The crash happens inside the RPC clnt_call(),
this is the backtrace from ddd:
Reading symbols from /net/csr/srv/projects/ctl/franksen/epics/ioc/MLS-
Controls/work-scopes/bin/linux-x86/SIOC3CP...done.
(gdb) core-file /net/csr/srv/projects/ctl/franksen/epics/ioc/MLS-
Controls/work-scopes/core
warning: core file may not match specified executable file.
[New Thread 29415]
[New Thread 29409]
[New Thread 29421]
[New Thread 29411]
[New Thread 29416]
[New Thread 29413]
[New Thread 29417]
[New Thread 29414]
[New Thread 29418]
[New Thread 29419]
[New Thread 29420]
warning: Can't read pathname for load map: Input/output error.
Core was generated by `../../bin/linux-x86/SIOC3CP ./st.cmd'.
Program terminated with signal 11, Segmentation fault.
#0  0x0041450d in clnttcp_call (h=0x98828f0, proc=11, xdr_args=0x80a2670
<xdr_Device_WriteParms>, args_ptr=0xb774a0cc "", xdr_results=0x80a23e0
<xdr_Device_WriteResp>, results_ptr=0xb774a0e4 "", timeout=...) at
clnt_tcp.c:258
        in clnt_tcp.c
Current language:  auto
The current source language is "auto; currently c".
(gdb) frame 1
#1  0x080987eb in clientIoCall (pvxiPort=0x9869350, pasynUser=<value
optimized out>, req=11, proc1=0x80a2670 <xdr_Device_WriteParms>,
addr1=0xb774a0cc "", proc2=0x80a23e0 <xdr_Device_WriteResp>,
addr2=0xb774a0e4 "") at ../../asyn/vxi11/drvVxi11.c:558
(gdb) frame 2
#2  0x080989e9 in vxiWrite (drvPvt=0x9869350, pasynUser=0x98825bc,
data=0x98819b4 "HDR 0;VERB ON;\r\n", numchars=16,
nbytesTransfered=0xb774a13c) at ../../asyn/vxi11/drvVxi11.c:1211
(gdb) frame 3
#3  0x0809b093 in writeIt (drvPvt=0x9871de0, pasynUser=0x98825bc,
nbytesTransfered=0xb774a1d8) at ../../asyn/asynGpib/asynGpib.c:396
(gdb) frame 4
#4  0x080a0080 in writeIt (drvPvt=0x9877d98, pasynUser=0x98825bc,
nbytesTransfered=0xb774a1d8) at ../../asyn/interfaces/asynOctetBase.c:223
(gdb) frame 5
#5  0x0806d712 in AsynDriverInterface::writeHandler (this=0x9882498) at
../AsynDriverInterface.cc:624
The current source language is "auto; currently c++".
(gdb) frame 6
#6  0x0806db20 in handleRequest (pasynUser=0x98825bc) at
../AsynDriverInterface.cc:1299
(gdb) frame 7
#7  0x0807fa0b in portThread (pport=0x9877320) at
../../asyn/asynDriver/asynManager.c:799
/net/csr/srv/projects/ctl/franksen/epics/support/asyn/4-11/asyn/asynDriver/asynManager.c:799:28962:beg:0x807fa0b
(gdb) frame 8
#8  0x08146d6f in start_routine (arg=0x9877c28) at
../../../src/libCom/osi/os/posix/osdThread.c:320
	in ../../../src/libCom/osi/os/posix/osdThread.c
(gdb)
I can't see anything obviously wrong, here, no NULL pointers, etc. Could
this be a bug in the RPC implementation? One that gets triggered by bad data
sent back from the server?
Any other ideas?
This is the IOC shell log:
franksen@tiber:~/ctl/MLS-Controls/work-scopes ______________________________
14:09:06
> cd iocBoot/iocSIOC3CP && ./st.cmd
#!../../bin/linux-x86/SIOC3CP
# Change to top directory
cd ../..
########################################################### Set up
Environment
epicsEnvSet IOC SIOC3CP
#epicsEnvSet LOG_DIR /opt/IOC/log
epicsEnvSet LOG_DIR /projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log
#epicsEnvSet EPICS_CA_PUT_LOG_INET 192.168.48.97
epicsEnvSet EPICS_CA_PUT_LOG_INET 193.149.12.189
epicsEnvSet EPICS_CA_SERVER_PORT 12345
epicsEnvSet VXI11_IO_TIMEOUT 1
epicsEnvSet VXI11_RPC_TIMEOUT 10
#VXI11_RECOVER_W_IFC 0 : no
#                    1 : yes
epicsEnvSet VXI11_RECOVER_W_IFC 1
epicsEnvSet GPIB_ADDR 1
epicsEnvSet GPIB_LINK L1
epicsEnvSet GPIB_VXI11_NAME gpib0
epicsEnvSet GPIB_GATEWAY gpibc3cp.mlscs.bessy.de
epicsEnvSet SCOPEC2S1GP_INET scopec2s1gp.mlscs.bessy.de
epicsEnvSet SCOPEC2S1GP_LINK L2
epicsEnvSet SCOPEC2S1GP_ADDR -1
epicsEnvSet SCOPEC2S1GP_VXI11_NAME inst0
epicsEnvSet STREAM_PROTOCOL_PATH db
############################################## Register all support
components
dbLoadDatabase dbd/SIOC3CP.dbd 0 0
SIOC3CP_registerRecordDeviceDriver pdbbase
############################################################ Configure
drivers
# Configure asyn vxi-11 driver
#vxi11Configure ${GPIB_LINK} ${GPIB_GATEWAY} ${VXI11_RECOVER_W_IFC}
${VXI11_IO_TIMEOUT} ${GPIB_VXI11_NAME}
vxi11Configure L2 scopec2s1gp.mlscs.bessy.de 0 1 inst0 0 1
#asynSetTraceMask ${GPIB_LINK} ${GPIB_ADDR} 0x0010
#asynSetTraceIOMask ${GPIB_LINK} ${GPIB_ADDR} 0x0003
#asynSetOption ${GPIB_LINK} -1 rpctimeout ${VXI11_RPC_TIMEOUT}
asynSetTraceMask L2 -1 0x001F
asynSetTraceIOMask L2 -1 0x0003
#asynSetOption ${SCOPEC2S1GP_LINK} -1 rpctimeout ${VXI11_RPC_TIMEOUT}
####################################################### Autosave
configuration
set_savefile_path /projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/autoSaveRestore
save_restoreSet_DatedBackupFiles 1
save_restoreSet_UseStatusPVs 0
######################################################## Load record
instances
dbLoadRecords db/SIOC-stats.db IOC=SIOC3CP
filename="../dbLexRoutines.c" line number=238
No such file or directory dbRead opening file db/SIOC-stats.db#dbLoadRecords
db/ScopeMeas.db  "DEVN=SCOPE1ZCP,ADDR=${GPIB_ADDR},LINK=${GPIB_LINK}"
dbLoadRecords db/ScopeMeas.db  "DEVN=SCOPEC2S1GP,ADDR=-1,LINK=L2"
######################################################## Restore record
values
set_pass0_restoreFile ScopeMeas.sav
########################################################### Configure IOC
Core
# IOC Log Server Connection  0=enabled 1=disabled
setIocLogDisable 0
# Configure Access Security
asSetFilename db/security.acf
#################################################################### Start
IOC
iocInit
Starting iocInit
###  EPICS IOC CORE built on Mar  3 2010
###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
save_restore: Can't figure out which seq file is most recent,
save_restore: so I'm just going to start with
'/projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/autoSaveRestore/ScopeMeas.sav0'.
save_restore: Can't find a file to restore from...save_restore: ...last
tried '/projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/autoSaveRestore/ScopeMeas.sav2'. I give up.
2010/03/16 14:09:14.864 L2 -1 registerInterruptUser
2010/03/16 14:09:14.865 L2 addr -1 queueRequest priority 3 not lockHolder
2010/03/16 14:09:14.865 asynManager connect queueCallback port:L2
2010/03/16 14:09:14.865 L2 addr -1 vxiConnect
2010/03/16 14:09:14.865 L2 vxiConnectPort
2010/03/16 14:09:16.020 L2SRQ read error: Connection reset by peer
2010/03/16 14:09:16.020 L2SRQ vxiSrqThread terminating
2010/03/16 14:09:16.020 L2 vxiCreateIrqChannel VXI: channel not established
(create_intr_chan)
2010/03/16 14:09:16.020 L2 Warning -- SRQ not operational.
2010/03/16 14:09:16.020 L2 asynGpib:srqHappened
2010/03/16 14:09:16.020 L2 addr -1 queueRequest priority 1 not lockHolder
2010/03/16 14:09:16.020 L2 addr -1 queueRequest priority 0 not lockHolder
2010/03/16 14:09:16.020 L2 schedule queueRequest timeout
2010/03/16 14:09:16.020 L2 callback
2010/03/16 14:09:16.020 L2 -1 vxiWrite numchars 16
[1]    25241 segmentation fault (core dumped)  ./st.cmd
franksen@tiber:~/ctl/MLS-Controls/work-scopes/iocBoot/iocSIOC3CP ___________
14:09:16
Cheers
Ben
Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC Benjamin Franksen
Prev: RE: Help Request: Setting up NIXI-1042/NI-MXI-4/DXP-XMAP withdxpStandalone_2-10 Mark Rivers
Next: Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Help Request: Setting up NIXI-1042/NI-MXI-4/DXP-XMAP withdxpStandalone_2-10 David Ehle
