1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC
To: [email protected]
Date: Wed, 17 Mar 2010 13:09:33 +0100
On Wednesday 17 March 2010, Benjamin Franksen wrote:
> I'm trying to talk to the mentioned scope via asyn/stream and get
>  mysterious crashes the first time the IOC tries to communicate over the
>  link. Below is a trace of the IOC shell up to the crash. I am using the
>  latest and greatest versions of everything except EPICS base:
>  base-3.14.8.2, asyn-4.11a (supposedly the last version that works with
>  base-3.14.8), StreamDevice-2- snapshot20081007. The crash happens on the
>  latest ubuntu version as well as on a debian stable system. I should
>  point out that with the exact same setup I can talk fine with e.g. a
>  GPIB controller.
Ok I did dome more research. GÃtz suggested valgrind and indeed I got
interesting results:
(1) When I run the IOC under valgrind it doesn't crash, it even talks to the
device. Nice.
(2) Valgrind complains about StreamDevice doing "Mismatched free() / delete
/ delete []". See below for a transcript.
My current theory is that these mismatched calls cause the memory free list
to become corrupted. Note that VXI-11 is based on RPC which heavily uses
malloc/free internally during runtime, so there is some probability that a
corrupted free list will lead to a crash inside the RPC library.
Dirk, could you look into this?
Cheers
Ben
PS: this is a log of the IOC shell run under valgrind:
> valgrind ../../bin/linux-x86/SIOC3CP ./st.cmd
==31115== Memcheck, a memory error detector
==31115== Copyright (C) 2002-2009, and GNU GPL'd, by Julian Seward et al.
==31115== Using Valgrind-3.5.0-Debian and LibVEX; rerun with -h for
copyright info
==31115== Command: ../../bin/linux-x86/SIOC3CP ./st.cmd
==31115==
#!../../bin/linux-x86/SIOC3CP
# Change to top directory
cd ../..
########################################################### Set up
Environment
epicsEnvSet IOC SIOC3CP
#epicsEnvSet LOG_DIR /opt/IOC/log
epicsEnvSet LOG_DIR /projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log
#epicsEnvSet EPICS_CA_PUT_LOG_INET 192.168.48.97
epicsEnvSet EPICS_CA_PUT_LOG_INET 193.149.12.189
epicsEnvSet VXI11_IO_TIMEOUT 1
epicsEnvSet VXI11_RPC_TIMEOUT 10
#VXI11_RECOVER_W_IFC 0 : no
#                    1 : yes
epicsEnvSet VXI11_RECOVER_W_IFC 1
epicsEnvSet GPIB_ADDR 1
epicsEnvSet GPIB_LINK L1
epicsEnvSet GPIB_VXI11_NAME gpib0
epicsEnvSet GPIB_GATEWAY gpibc3cp.mlscs.bessy.de
epicsEnvSet SCOPEC2S1GP_INET 192.168.101.116
epicsEnvSet SCOPEC2S1GP_LINK L2
epicsEnvSet SCOPEC2S1GP_ADDR -1
epicsEnvSet SCOPEC2S1GP_VXI11_NAME inst0
epicsEnvSet STREAM_PROTOCOL_PATH db
############################################## Register all support
components
dbLoadDatabase dbd/SIOC3CP.dbd 0 0
SIOC3CP_registerRecordDeviceDriver pdbbase
############################################################ Configure
drivers
# Configure asyn vxi-11 driver
#vxi11Configure ${GPIB_LINK} ${GPIB_GATEWAY} ${VXI11_RECOVER_W_IFC}
${VXI11_IO_TIMEOUT} ${GPIB_VXI11_NAME}
vxi11Configure L2 192.168.101.116 0 1 inst0 0 1
#asynSetTraceMask ${GPIB_LINK} ${GPIB_ADDR} 0x0010
#asynSetTraceIOMask ${GPIB_LINK} ${GPIB_ADDR} 0x0003
#asynSetOption ${GPIB_LINK} -1 rpctimeout ${VXI11_RPC_TIMEOUT}
#asynSetTraceMask ${SCOPEC2S1GP_LINK} ${SCOPEC2S1GP_ADDR} 0x001F
#asynSetTraceIOMask ${SCOPEC2S1GP_LINK} ${SCOPEC2S1GP_ADDR} 0x0003
#asynSetOption ${SCOPEC2S1GP_LINK} -1 rpctimeout ${VXI11_RPC_TIMEOUT}
####################################################### Autosave
configuration
set_savefile_path /projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/autoSaveRestore
save_restoreSet_DatedBackupFiles 1
save_restoreSet_UseStatusPVs 0
######################################################## Load record
instances
dbLoadRecords db/SIOC-stats.db IOC=SIOC3CP
#dbLoadRecords db/ScopeMeas.db
"DEVN=SCOPE1ZCP,ADDR=${GPIB_ADDR},LINK=${GPIB_LINK}"
dbLoadRecords db/ScopeMeas.db  "DEVN=SCOPEC2S1GP,ADDR=-1,LINK=L2"
######################################################## Restore record
values
#set_pass0_restoreFile ScopeMeas.sav
########################################################### Configure IOC
Core
# IOC Log Server Connection  0=enabled 1=disabled
setIocLogDisable 1
# Configure Access Security
#asSetFilename db/no_security.acf
#################################################################### Start
IOC
iocInit
Starting iocInit
###  EPICS IOC CORE built on Mar  3 2010
###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
initHooks: set_pass[0,1]_restoreFile() were never called.
initHooks: Specifying 'auto_settings.sav' and 'auto_positions.sav'
initHooks: for backward compatibility with old autosave/restore.
save_restore: Can't figure out which seq file is most recent,
save_restore: so I'm just going to start with
'/projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/autoSaveRestore/auto_positions.sav0'.
save_restore: Can't find a file to restore from...save_restore: ...last
tried '/projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/autoSaveRestore/auto_positions.sav2'. I give up.
scopes/log/autoSaveRestore/auto_settings.sav0'.
scopes/log/autoSaveRestore/auto_settings.sav2'. I give up.
==31115== Mismatched free() / delete / delete []
==31115==    at 0x402554D: operator delete(void*) (vg_replace_malloc.c:346)
==31115==    by 0x80598F3: StreamBuffer::grow(long) (StreamBuffer.cc:105)
==31115==    by 0x805DCEC: StreamProtocolParser::readToken(StreamBuffer&,
char const*, bool) (StreamBuffer.h:42)
==31115==    by 0x805F16C: StreamProtocolParser::parseValue(StreamBuffer&,
bool) (StreamProtocol.cc:602)
==31115==    by 0x805FA62:
StreamProtocolParser::parseProtocol(StreamProtocolParser::Protocol&,
StreamBuffer*) (StreamProtocol.cc:406)
==31115==    by 0x805FBEE:
StreamBuffer*) (StreamProtocol.cc:370)
==31115==    by 0x806001C:
StreamProtocolParser::StreamProtocolParser(_IO_FILE*, char const*)
(StreamProtocol.cc:73)
==31115==    by 0x80602B3: StreamProtocolParser::readFile(char const*)
(StreamProtocol.cc:201)
==31115==    by 0x80603B7: StreamProtocolParser::getProtocol(char const*,
StreamBuffer const&) (StreamProtocol.cc:135)
==31115==    by 0x8064818: StreamCore::parse(char const*, char const*)
(StreamCore.cc:216)
==31115==    by 0x80588E7: Stream::initRecord() (StreamEpics.cc:620)
==31115==    by 0x8058C3E: streamInitRecord (StreamEpics.cc:426)
==31115==  Address 0x44540d0 is 0 bytes inside a block of size 128 alloc'd
==31115==    at 0x4026024: operator new[](unsigned int)
(vg_replace_malloc.c:258)
==31115==    by 0x80598A7: StreamBuffer::grow(long) (StreamBuffer.cc:99)
==31115==    by 0x805DE99: StreamProtocolParser::readToken(StreamBuffer&,
(StreamCore.cc:216)
==31115==
==31115==    by 0x805BDF7:
StreamProtocolParser::Protocol::Variable::~Variable() (StreamBuffer.h:67)
==31115==    by 0x805BE6B: StreamProtocolParser::Protocol::~Protocol()
(StreamProtocol.cc:767)
==31115==    by 0x8064877: StreamCore::parse(char const*, char const*)
(StreamCore.cc:228)
==31115==    by 0x8053D9A: initRecord (devaiStream.c:80)
==31115==    by 0x80A64AA: init_record (aiRecord.c:143)
==31115==    by 0x80C38F4: iocInit (iocInit.c:351)
==31115==    by 0x80C3286: iocInitCallFunc (dbAccessRegister.c:69)
==31115==    by 0x80C09BD: iocshBody (iocsh.cpp:743)
==31115==    by 0x8053B1C: main (SoftIocMain.cpp:24)
==31115==  Address 0x4455ae8 is 0 bytes inside a block of size 128 alloc'd
==31115==    by 0x8059B5B: StreamBuffer::init(void const*, long)
(StreamBuffer.cc:44)
==31115==    by 0x805A7D6:
StreamProtocolParser::Protocol::Variable::Variable(StreamProtocolParser::Protocol::Variable
const&) (StreamBuffer.h:61)
==31115==    by 0x805A99C:
StreamProtocolParser::Protocol::Protocol(StreamProtocolParser::Protocol
const&, StreamBuffer&, int) (StreamProtocol.cc:744)
==31115==    by 0x805BCE4: StreamProtocolParser::getProtocol(StreamBuffer
const&) (StreamProtocol.cc:239)
==31115==    by 0x8060353: StreamProtocolParser::getProtocol(char const*,
StreamBuffer const&) (StreamProtocol.cc:142)
(StreamCore.cc:216)
==31115==
==31115==    by 0x80596BC: StreamBuffer::replace(long, long, void const*,
long) (StreamBuffer.cc:215)
==31115==    by 0x80606CB:
StreamProtocolParser::Protocol::compileString(StreamBuffer&, char const*&,
FormatType, StreamProtocolParser::Client*, int) (StreamBuffer.h:145)
==31115==    by 0x80666C5:
StreamCore::compileCommand(StreamProtocolParser::Protocol*, StreamBuffer&,
char const*, char const*&) (StreamCore.cc:306)
==31115==    by 0x805C9B8:
StreamProtocolParser::Protocol::compileCommands(StreamBuffer&, char const*&,
StreamProtocolParser::Client*) (StreamProtocol.cc:1646)
==31115==    by 0x805CB72: StreamProtocolParser::Protocol::getCommands(char
const*, StreamBuffer&, StreamProtocolParser::Client*)
(StreamProtocol.cc:924)
==31115==    by 0x8064586:
StreamCore::compile(StreamProtocolParser::Protocol*) (StreamCore.cc:274)
==31115==    by 0x806482A: StreamCore::parse(char const*, char const*)
(StreamCore.cc:222)
==31115==  Address 0x445fbb0 is 0 bytes inside a block of size 128 alloc'd
==31115==    by 0x8059625: StreamBuffer::replace(long, long, void const*,
long) (StreamBuffer.cc:208)
(StreamCore.cc:222)
==31115==
==31115==    by 0x8060A6E:
FormatType, StreamProtocolParser::Client*, int) (StreamBuffer.h:67)
(StreamCore.cc:222)
==31115==  Address 0x445fd90 is 0 bytes inside a block of size 128 alloc'd
==31115==    by 0x8059AAE: StreamBuffer::append(void const*, long)
(StreamBuffer.h:42)
==31115==    by 0x805D6C7:
StreamProtocolParser::Protocol::compileFormat(StreamBuffer&, char const*&,
FormatType, StreamProtocolParser::Client*) (StreamBuffer.h:118)
==31115==    by 0x806065B:
FormatType, StreamProtocolParser::Client*, int) (StreamProtocol.cc:1115)
(StreamCore.cc:222)
==31115==
iocInit: All initialization complete
## Report Installed and Configured I/O-Hardware Information
dbior 0 1 > /projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/Database/SIOC3CP.dbior
dbhcr     > /projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/Database/SIOC3CP.dbhcr
dbl       > /projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/Database/SIOC3CP.dbl
system "cp iocBoot/version /projects/ctl/franksen/epics/ioc/MLS-
Controls/work-scopes/log/Database/SIOC3CP.version"
cp: cannot stat `iocBoot/version': No such file or directory
system "pwd | tee /projects/ctl/franksen/epics/ioc/MLS-Controls/work-
scopes/log/Database/SIOC3CP.pwd"
/net/csr/srv/projects/ctl/franksen/epics/ioc/MLS-Controls/work-scopes
############################################################ Sequence
programs
#seq sncxxx var=value
################################################# Create autosave monitor
sets
#create_monitor_set db/ScopeMeas.req 5 "DEVN=SCOPE1ZCP"
#create_monitor_set db/ScopeMeas.req 5 "DEVN=SCOPEC2S1GP"
caPutLogging
#caPutLogInit ${EPICS_CA_PUT_LOG_INET} 0
#asynSetTraceMask ${GPIB_LINK} ${GPIB_ADDR} 0x0000
#system "cat iocBoot/version"
exit
epics> ^C==31115==
==31115== HEAP SUMMARY:
==31115==     in use at exit: 1,226,282 bytes in 11,551 blocks
==31115==   total heap usage: 12,520 allocs, 969 frees, 1,426,883 bytes
allocated
==31115==
==31115== LEAK SUMMARY:
==31115==    definitely lost: 367 bytes in 14 blocks
==31115==    indirectly lost: 0 bytes in 0 blocks
==31115==      possibly lost: 380,001 bytes in 8,611 blocks
==31115==    still reachable: 845,914 bytes in 2,926 blocks
==31115==         suppressed: 0 bytes in 0 blocks
==31115== Rerun with --leak-check=full to see details of leaked memory
==31115==
==31115== For counts of detected and suppressed errors, rerun with: -v
==31115== ERROR SUMMARY: 81 errors from 4 contexts (suppressed: 27 from 6)
[1]    31115 killed     valgrind ../../bin/linux-x86/SIOC3CP ./st.cmd
franksen@tiber:~/ctl/MLS-Controls/work-scopes/iocBoot/iocSIOC3CP ___________
12:57:48
Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC Kazuro FURUKAWA
Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC Benjamin Franksen
Prev: Tektronic Scope DPO7254 over VXI-11 crashes IOC Benjamin Franksen
Next: RE: Help Request: Setting up NIXI-1042/NI-MXI-4/DXP-XMAP withdxpStandalone_2-10 David Ehle
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC Kazuro FURUKAWA
