1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Thu, 18 Mar 2010 06:04:12 +0900
Hello Ben,
Some of the old vxi11.x implementations were designed assuming
long=32bit.  If I remember correctly, VXI-11 document was one of
them.  I had to modify it for 64bit architecture some time ago.
As we didn't modify AsynDriver, I hope this is not the issue :-).
We run ~30 oscilloscopes of DPO7104/7254 at KEKB and KEK linac.
As they have good CPUs inside (~3GHz), we run embedded IOCs on
all of them.  While VXI-11 on DPO7000 is relatively fast, an
embedded IOC with a dedicated (synchronous) device-support is
faster and more reliable.
(Before this implementation I was afraid of the stability of
Windows.  However, this embedded IOC turned out to be rather
reliable.)
Cheers,
Kazuro.
>>> On Wed, 17 Mar 2010 13:09:33 JST,  Benjamin Franksen <[email protected]> wrote;
> On Wednesday 17 March 2010, Benjamin Franksen wrote:
> > I'm trying to talk to the mentioned scope via asyn/stream and get
> >  mysterious crashes the first time the IOC tries to communicate over the
> >  link. Below is a trace of the IOC shell up to the crash. I am using the
> >  latest and greatest versions of everything except EPICS base:
> >  base-3.14.8.2, asyn-4.11a (supposedly the last version that works with
> >  base-3.14.8), StreamDevice-2- snapshot20081007. The crash happens on the
> >  latest ubuntu version as well as on a debian stable system. I should
> >  point out that with the exact same setup I can talk fine with e.g. a
> >  GPIB controller.
> Ok I did dome more research. G旦tz suggested valgrind and indeed I got
> interesting results:
> (1) When I run the IOC under valgrind it doesn't crash, it even talks to the
> device. Nice.
> (2) Valgrind complains about StreamDevice doing "Mismatched free() / delete
> / delete []". See below for a transcript.
> My current theory is that these mismatched calls cause the memory free list
> to become corrupted. Note that VXI-11 is based on RPC which heavily uses
> malloc/free internally during runtime, so there is some probability that a
> corrupted free list will lead to a crash inside the RPC library.
> Dirk, could you look into this?
> Cheers
> Ben
> PS: this is a log of the IOC shell run under valgrind:
(* log removed *)
Kazuro FURUKAWA <[email protected]>
 Linac&KEKB,  High Energy Accelerator Research Organization (KEK), Japan
 Telephone: +81-29-864-5200 x4316,  Facsimile: +81-29-864-0321
Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC Benjamin Franksen
Prev: RE: Help Request: Setting up NIXI-1042/NI-MXI-4/DXP-XMAP withdxpStandalone_2-10 David Ehle
Next: what is the withMPF.dbd? 汪启胜
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC Benjamin Franksen
Next: Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC Benjamin Franksen
