1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm : TwoDProfileMonitorClass : cropping/resizing image
To: Bruce Hill <[email protected]>, [email protected]
Date: Wed, 24 Mar 2010 10:01:18 -0400
Bruce Hill wrote:
I started working on testing your changes, but it appears you're working
from an earlier copy of TwoDProfileMonitorClass than I have. Would
you mind sending me a copy of the original file you started from, or a diff?
For the newer version of TwoDProfileMonitorClass, there are "widthOffsetPvBuff"
and "heightOffsetPvBuf", which I need to replace them with names that we can
use for either XY lineout and ROI, depending on the mode of the one-click activation.
Thus, I worked from the earlier version of TwoDProfileMonitorClass. The
entire edm TwoDProfileMonitorClass package, including the original file and
a new README, is now posted at
http://www.nsls.bnl.gov/facility/expsys/software/EPICS/
under the "updated S/W". Hope this helps.
Cheers,
Kate
Re: edm : TwoDProfileMonitorClass : cropping/resizing image Kate Feng
Prev: EPICS Base bugs moved to Launchpad Andrew Johnson
Next: Gateways and IOC UAG security: does username to relayed with request? Carl Schumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: edm : TwoDProfileMonitorClass : cropping/resizing image Kate Feng
Next: A patch for libXpm.a (was Re: edm : TwoDProfileMonitorClass : cropping/resizing image) Kate Feng
