Subject: |
Gateways and IOC UAG security: does username to relayed with request? |
Carl Schumann <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 24 Mar 2010 11:38:01 -0500 |
We have an IOC that only permits writes from a subset of users. The IOC
implements this security using UAG security and it works as expected for
applications running on the IOC's subnet. Applications that are not
on that IOC's subnet must access it through a gateway. These off the
subnet applications can not make any settings even for users that are in
the permitted subset. This has also been verified using cainfo.
Does the username of the user running the application make it through
the gateway to the IOC? Our guess is no, because the gateway
permissions are wide-open and writes to other IOC's without UAG security
work fine. How should this kind of issue be handled? I know there
is a -uid command line option but single uid will be correct for all users.
Carl Schumann
- Re: Gateways and IOC UAG security: does username to relayed with request? Martin L. Smith
Re: edm : TwoDProfileMonitorClass : cropping/resizing image Kate Feng
<2010>
2025
2026
EPICS Base bugs moved to Launchpad Andrew Johnson
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
