Hi Carl,
I do this kind of thing extensively and quite routinely.
The user name making the request to the GW does not get passed through to the
other subnet. Instead the user that started the PV gateway process I believe is
the one that the IOC sees. I use a second layer of Access Security in the GW to
access PVs in the IOC.
In my gateway.starter file I have included in the command to start the GW
-gid 55 -uid 265 -server & This I believe will start the GW under the given gid
and uid which is what the IOC sees I think .... at least in my case. Then you
need to allow users (UAG) from the requesting subnet write access to the ASG in
the IOC ... at least this is how I do it.
Then in the IOC you must specifically allow write access from the GW uid in your
access security file.
I can send you an example if you would like.
Marty
Carl Schumann wrote:
We have an IOC that only permits writes from a subset of users. The IOC
implements this security using UAG security and it works as expected for
applications running on the IOC's subnet. Applications that are not
on that IOC's subnet must access it through a gateway. These off the
subnet applications can not make any settings even for users that are in
the permitted subset. This has also been verified using cainfo.
Does the username of the user running the application make it through
the gateway to the IOC? Our guess is no, because the gateway
permissions are wide-open and writes to other IOC's without UAG security
work fine. How should this kind of issue be handled? I know there
is a -uid command line option but single uid will be correct for all users.
Carl Schumann
- Re: Gateways and IOC UAG security: does username to relayed with request? Ralph Lange
- Gateways and IOC UAG security: does username to relayed with request? Carl Schumann
<2010>
2025
2026
<2010>
2025
2026
