Title: RE: create arrays in EDM
On 04/03/2010 02:10 PM, Dalesio, Leo wrote:
It is not totally clear what the goal is......
For collecting scalars into arrays - the Compress record already does
this. Bad name, I know, but it also compresses waveform records. So if
the input is an array, it does successive averages or filters
high,low,average. If the input is a scalar, it is a circular buffer. If
all you want to do is take a scalar, and create a histogram, there is a
histogram record.
The subroutine record - as Stephanie points out - also gives you a way
to take one or several arrays, and manipulate them to create a result
(or several results)
If you are trying to marshal many scalars into an array, then there are
more questions before answers. Do you need location? Status for each
channel? Time stamp or time difference from some reference? Does one
channel become the reference? We are working on this type of support to
create a suite of tools right now at NSLS. Hopefully, we have some
progress to report at the May meeting in Aix.
Firstly i would like to thank you all for the responses.
I re-read my first email and i forgot to mention that the scalars i am
trying to put into an array are
not located on the same machine.
For an example:
there are 200 computers (machines) each running their own EPICS server
connected
in the same network. I am able to read the temperatures of each through
an EPICS PV (fo example using caget).
Now, on another computer (in the same network) in the administration
room i would like to monitor all these
temperatures using EDM (or if it is not possible with EDM some other
visualization tool).
But the usual way of displaying this, a box changing colors (red,
yellow, green) is not
enough and also displaying 200 numbers is not user-friendly for the
administrator.
What i would like to achieve is to get all these temperatures and
collect them into
an array and display them onto a X-Y Graph. This way the administrator
would be able to see
what is the temperature and also how much it is drifting from
desired/average/reference. The x-axis are the machines depending on
their own index number, which is fixed. So Machine001 would always be
the first in the array (to display), which means
that the location is very important.
Time stamp and time differences are not crucial, they could be a nice
feature but not important at the moment.
Since all the readings should be independent the timestamp is not
important.
One option for the reference could be the average from all, but this
one would be selectable.
The administrator would choose which is the desired temperature of the
specific machine depending
on the position of the machine, the usage of the cooling system etc.
If you only need a plug in EDM, look at the CALC
example. If has channel access on one side and creates a result on the
other side.
Bob
I will take a look if CALC can collect different scalars and create an
array.
As i understood the CALC is limited with the number of variables it can
process.
Also if i understand Stephanie correctly one variant would be to have a
softIOC running on the
administrators computer which would collect all the scalars and create
the waveform record.
The EDM would display the updated waveform record. This sounds as a
very good solution
to the problem.
The suggestion made by Matt Newville to use of EpicsCA module in python
is also a very good alternative.
It will definitely be useful for some other work too. Thanks for
pointing this one out for me.
I hope the above description gives a general idea what i want to do.
Maybe i have mislead some of you
when i mentioned histograms, but that was one of the associations that
popped in my mind.
Jovan
- Re: create arrays in EDM Ned Arnold
- Re: create arrays in EDM Andrew Johnson
- create arrays in EDM Jovan Loncar
- RE: create arrays in EDM Allison, Stephanie
- RE: create arrays in EDM Dalesio, Leo
Re: JCA type conversion Simon Ebner
<2010>
2025
2026
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
