1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cac_select_io Segmentation fault
To: Al Honey <[email protected]>
Cc: [email protected]
Date: Wed, 07 Apr 2010 09:21:39 -0400
EPICS 3.13.10 is six years old and frozen. Lots of bugs have been fixed since then.
(That's why I fear you might experience limited support enthusiasm.)
Any particular reason why you can't use a recent version?
(As you are connecting to Unix IOCs, you seem to have 3.14 built and running.)
Cheers,
Ralph
On Tue 06 Apr 2010 19:57:08 Al Honey wrote:
Aloha
I am trying to get a multi-threaded application working on SunOs 5.10 with connection to two UNIX IOC’s.
I get a seg fault for ellDelete, two statements from the end of cac_select_io() (epics/r3.13.10/base/src/ca/bsd_depen.c).
The seg fault does not occur immediately but within a couple of minutes (connections are to two IOC’s running on UNIX, with events from two long records on each IOC, where one record on each system is updated at 1 hz and the other at 10 hz).
Does the seg fault occur because r3.13.10 is NOT thread safe?
Does anyone have an example of a multi-threaded app using r3.13.10 on UNIX?
Allan
cac_select_io Segmentation fault Al Honey
Prev: EDM text entry: segmentation fault Dmitry Teytelman
Next: EDM text entry: segmentation fault Sharon Lackey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: cac_select_io Segmentation fault Al Honey
Next: Re: cac_select_io Segmentation fault Ralph Lange
