Hello all!
I am at my wits end and will take any help I can get. Here is the
problem. EDM crashes with a segfault when executing any panel with a
text entry field (unconnected fields do not cause the fault). I have
tracked the crash to the following call in pvFactory/textupdate.cc:
XtVaSetValues(widget,
XmNeditable, True,
XmNforeground, (XtArgVal)textColor.getPixel(actWin->ci),
NULL);
If I change XmNeditable from True to False, the segfault goes away.
Unfortunately EDM is not useable with that little mod :)
All of this under Red Hat Enterprise Linux 5.4. Has anybody seen
similar behavior?
Thanks in advance!
Dmitry Teytelman
- Re: EDM text entry: segmentation fault Andrew Johnson
cac_select_io Segmentation fault Al Honey
Re: cac_select_io Segmentation fault Ralph Lange
<2010>
2025
2026
RE: cac_select_io Segmentation fault Jeff Hill
<2010>
2025
2026
