1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: cac_select_io Segmentation fault
To: "'Al Honey'" <[email protected]>
Cc: [email protected]
Date: Wed, 7 Apr 2010 15:50:29 -0600
Allan,
I should mention also that, with R3.14, an application thread isn’t allowed to participate in a preexisting CA context unless it makes a CA call requesting to join that context. If not, it will implicitly create a new CA context when it calls the CA client library.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
Sent: Wednesday, April 07, 2010 3:44 PM
To: 'Al Honey'
Cc: '[email protected]'
Allan,
It does sound like optical telescope upgrades are a tad bit more challenging, and schedule risk exposed, compared to what we typically see in the particle accelerator world.
We have actually made the network behavior of EPICS systems as a whole more robust under load in R3.14. The main change has been that network congestion induced disconnects do _not_ cause positive congestion feedback. In practice this means that the client library disconnects the application, but not the TCP circuit when a CA channel times out. A large number of other subtle issues have also been fixed, and KECK can quickly benefit from many of them by switching all the apps to R3.14 even if the IOCs must stay at R3.13 because it takes more time to complete their upgrade work.
Ø  We have deployed r3.14 caRepeaters
I wouldn’t expect any functionally different behavior between the R3.14 and R3.13 CA repeaters, but I am very willing to have a look at some additional details to see what might be occurring. At some point we did change from using the fork system call to auto-start the CA repeater to using the exec system call which is certainly a behavior change, but I seem to recall that this change was made as a patch at some point to R3.13. The big change here is avoidance of duplicating resources created by an application into the CA repeater’s process, and problems with the CA repeater process having a strange name belonging to the app that stated it. One can of course avoid such issues altogether by starting the CA repeater in the workstation’s boot script.
Ø  And we have some random issues: sometimes we have ‘get’ failure
Ø  responses, indicating channels are disconnected or non-existant,
Ø  in one client, whilst other clients are happy;
This can certainly occur if there is CPU saturation in the IOC, buffer starvation in the IOC’s IP kernel, or possibly also if you have a really old network with hubs instead of switches. Old Ethernet networks can experience delays if you have collision chains of sufficient magnitude. Another possibility is applications with too-short connection timeouts configured. Here at LANL I have, only on one project, seen a weird situation where many HP CAD workstations were configured with the wrong network/host partitioning mask, and they were responding to CA search requests with an ICMP error response. That was causing the IP input queue on the CA client’s host to get saturated, and this led to CA connects taking much longer to complete than they should have. Otherwise not expected.
Ø  responses from multiple IOCs for a given channel when only one of
Ø  those IOCs has that channel.
Not expected, and I don’t recall hearing complaints in this area. If the CA client library received a search response from the wrong IOC it will try to connect to the wrong IOC, fail doing that, and then return to searching for the channel where it would presumably eventually find the correct IOC.
Ø  I have not had time to delve into those. The errors seem
Ø  to be realtime IOC/board and/or possibly vxWorks related, as there
Ø  is one newer processor (not PPC as are most of the others) running
Ø  a newer version of vxWorks, from which I never see those types of errors.
Some earlier vxWorks had substantial issues with mbuf starvation and driver buffer pool starvation. As I recall, the SNS resolved these issues by allocating more m-bufs and cluster-bufs at vxWorks kernel build time, and by installing all of the very latest vxWorks network interface driver patches. The network congestion robustness improvements in R3.14 probably helped also.
Ø  Does someone have a simple multi-threaded example, utilizing r3.14
Ø  (so I can compare the CA library calls with what we are currently using in r3.13.10)?
The CA client interfaces are very close to 100% backwards compatible. There are some new interfaces that enable new features of course. Hopefully I am not oversimplifying the situation, but it’s probably safe to say that the primary multi-threading issue will be with how to properly structure your app for multi-threading as all of the multi-threading issues related to CA internals have been dealt with when preparing the first releases of R3.14. As mentioned in previous mm, you will also need to decide if you want non-preemptive callback which requires periodic calls to ca_poll from your thread, or non-preemptive callback where you will receive asynchronous callbacks from the CA client library. Asynchronous callbacks will of course require some additional expertise. The application may need some additional mutual exclusion primitives to control asynchronous access into the application’s data structures originating from multiple instances of the CA client library’s auxiliary threads.
Jeff
[email protected]
Sent: Wednesday, April 07, 2010 1:26 PM
To: Jeff Hill
No negativity noticed J
We have deployed r3.14 caRepeaters. And we have some random issues: sometimes we have ‘get’ failure responses, indicating channels are disconnected or non-existant, in one client, whilst other clients are happy; responses from multiple IOCs for a given channel when only one of those IOCs has that channel. I have not had time to delve into those. The errors seem to be realtime IOC/board and/or possibly vxWorks related, as there is one newer processor (not PPC as are most of the others) running a newer version of vxWorks, from which I never see those types of errors.
I think our big issue, with respect to forging forward with multi-thread clients, (i.e. using r3.14 for all clients) is that major modifications would need to be made to the layer we have between CA and our clients (said layer hides CA, as it is not the only inter-process/processor communications mechanism in place, for instance we have numerous RPC systems; and other socket based systems). Most of our operational clients do not interface directly to CA. Hence, that ‘layer’ is critical. It was the application interface provided to all our sister institutions (which create non-EPICS/CA instruments/systems) back in the early 90’s. I have been studying that ‘layer’ in great detail, in my attempt to solve the multi-threaded issue (r3.13.10), and it may be that I am now sufficiently less ignorant that I can make those modifications. If that is the case then I will no doubt have more questions.  So, thanks for pointing me to pertinent documents that will make the transition form r3.13.10 to r.3.14 possible.
Does someone have a simple multi-threaded example, utilizing r3.14 (so I can compare the CA library calls with what we are currently using in r3.13.10)?
Cheers,
Al
Sent: Wednesday, April 07, 2010 6:45 AM
To: Al Honey
Aloha again Allan,
Sorry, after rereading my message,  the tone sounds a bit negative which wasn’t my intent. I should have said, “please read also the section in the reference manual entitled - Thread Safety and Preemptive Callback to User Code”. When designing this type of application, one must decide if CA callbacks should occur only when periodically executing in a CA client library function such as ca_poll, or if the CA callbacks should occur asynchronously, as soon as the network messages are processed by the auxiliary threads in the library. Either approach can be used in a multi-threaded program.
Jeff
[email protected]
From: [email protected] [mailto:[email protected]] On Behalf Of Jeff Hill
Sent: Wednesday, April 07, 2010 8:38 AM
To: 'Al Honey'; [email protected]
Aloha Allan,
Ø  Does the seg fault occur because r3.13.10 is NOT thread safe?
The R3.13 CA Client library is definitely __not__ thread safe, and I can easily imagine that this might be the cause of your seg fault.
Ø  Does anyone have an example of a multi-threaded app using r3.13.10 on UNIX?
The R3.14 CA client library _is_ thread safe, and it should also interoperate fine with R3.13 IOCs. We routinely operate LANSCE with that configuration in our production system. Our control room runs R3.14, but many of our IOCs still run R3.13. You should read the section in the reference manual entitled “Thread Safety and Preemptive Callback to User Code“.
Jeff
[email protected]
From: [email protected] [mailto:[email protected]] On Behalf Of Al Honey
Sent: Tuesday, April 06, 2010 5:57 PM
To: [email protected]
Subject: cac_select_io Segmentation fault
Aloha
I am trying to get a multi-threaded application working on SunOs 5.10 with connection to two UNIX IOC’s.
I get a seg fault for ellDelete, two statements from the end of cac_select_io() (epics/r3.13.10/base/src/ca/bsd_depen.c).
The seg fault does not occur immediately but within a couple of minutes (connections are to two IOC’s running on UNIX, with events from two long records on each IOC, where one record on each system is updated at 1 hz and the other at 10 hz).
Allan
cac_select_io Segmentation fault Al Honey
RE: cac_select_io Segmentation fault Jeff Hill
RE: cac_select_io Segmentation fault Al Honey
Prev: RE: cac_select_io Segmentation fault Jeff Hill
Next: RE: create arrays in EDM Andrew C. Starritt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: cac_select_io Segmentation fault Al Honey
Next: EDM text entry: segmentation fault Dmitry Teytelman
