1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn port question
To: "Davidsaver, Michael" <[email protected]>
Cc: [email protected]
Date: Fri, 9 Apr 2010 13:27:37 -0700
The specification sheet for the WaveSurfer scope (http://www.lecroy.com/files/pdf/LeCroy_WaveSurfer_XS-a_Specs.pdf) claims LXI compliance -- which implies VXI-11 does it not?
On Apr 9, 2010, at 10:45 AM, Davidsaver, Michael wrote:
> All,
> I am looking at a Lecroy wavesurfer scope which is capable of remote
> control via. a tcp protocol.  The protocol is basically ascii text, but
> is grouped into frames with an 8 byte header.  The header has some bits
> for things like EOI and SRQ and a 32-bit size field.  Basically, this is
> a simpler (primitive?) way to accomplish the same thing as VXI-11.
> I haven't done more then read about asyn, but it seems like what I would
> want to do is create an adapter which uses a tcp client port and
> implements a gpib port.  What I don't know is: how complicated/difficult
> would this be?
> http://www.lecroy.com/tm/library/manuals/X-Stream_Scopes/RemoteControlMa
> nual/WM-RCM-E_Rev_D.pdf
> See chapter 3 "Control by LAN"
> Thanks,
> Michael Davidsaver
> NSLSII Controls Group
> Brookhaven National Lab
Eric Norum
[email protected]
RE: asyn port question Davidsaver, Michael
Prev: RE: asyn port question Mark Rivers
Next: RE: asyn port question Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
