> The specification sheet for the WaveSurfer scope
> (http://www.lecroy.com/files/pdf/LeCroy_WaveSurfer_XS-a_Specs.pdf)
> claims LXI compliance -- which implies VXI-11 does it not?
In fact it does. I did a quick check with the python-vxi11 extension
and '*IDN?' works without problem.
So I guess I was looking at the wrong manual? For reference this is a
wavesurfer 104MXs.
Anyway, thanks Eric and Mark!
> On Apr 9, 2010, at 10:45 AM, Davidsaver, Michael wrote:
> > All,
> > I am looking at a Lecroy wavesurfer scope which is capable of remote
> > control via. a tcp protocol. The protocol is basically ascii text,
> but
> > is grouped into frames with an 8 byte header. The header has some
> bits
> > for things like EOI and SRQ and a 32-bit size field. Basically,
this
> is
> > a simpler (primitive?) way to accomplish the same thing as VXI-11.
> > I haven't done more then read about asyn, but it seems like what I
> would
> > want to do is create an adapter which uses a tcp client port and
> > implements a gpib port. What I don't know is: how
> complicated/difficult
> > would this be?
> > http://www.lecroy.com/tm/library/manuals/X-
> Stream_Scopes/RemoteControlMa
> > nual/WM-RCM-E_Rev_D.pdf
> > See chapter 3 "Control by LAN"
> > Thanks,
> > Michael Davidsaver
> > NSLSII Controls Group
> > Brookhaven National Lab
> Eric Norum
> [email protected]
- asyn port question Davidsaver, Michael
- Re: asyn port question Eric Norum
RE: device support PINI problem Mark Rivers
command line tool to list all field values of a Record ? John Dobbins
<2010>
2025
2026
RE: asyn port question Davidsaver, Michael
how to process other records in subroutine record by ca link? Silver
<2010>
2025
2026
