1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: how to process other records in subroutine record by ca link?
To: "tech-talk" <[email protected]>
Date: Sat, 10 Apr 2010 20:06:41 +0800
hi,
  My case is like this:
  1. I can get a waveform value from one PV.
  2. After gaining the value, it will FLNK a subroutine record. then I want to do come caculation in subroutine record, such as caculating the steps which motor need move.
  3. to drive the motor, I will first set an ao record (motor:steps) a value, than set a bo record (motor:move) to run the motor.
  I have used the subroutine/gensub record before, but I don't know how to drive the other record in it, use dbCaPutLink? Where can I find detailed examples? Can anyone help me? thank a lot for your help.
  Ps, as I need to set the steps of motor differently each time, so can't just use FLNK in db file. Also I don't want to use Sequencer.
#include <stdio.h>
#include <dbDefs.h>
#include <registryFunction.h>
#include <subRecord.h>
#include <epicsExport.h>
int mySubDebug;
typedef long (*processMethod)(subRecord *precord);
static long mySubInit(subRecord *precord,processMethod process)
    if (mySubDebug)
        printf("Record %s called mySubInit(%p, %p)\n",
               precord->name, (void*) precord, (void*) process);
    return(0);
static long mySubProcess(subRecord *precord)
    if (mySubDebug)
      /*        printf("Record %s called mySubProcess(%p)\n",
		precord->name, (void*) precord);*/
      printf("Record %s called mySubProcess(%p),VAL=%f\n",precord->name, (void*) precord, (precord->a/123.456));
    return(0);
/* Register these symbols for use by IOC code: */
epicsExportAddress(int, mySubDebug);
epicsRegisterFunction(mySubInit);
epicsRegisterFunction(mySubProcess);
Best regards
Geyang  2010-04-10
Re: how to process other records in subroutine record by ca link? Eric Norum
Prev: RE: asyn port question Davidsaver, Michael
Next: Re: how to process other records in subroutine record by ca link? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
