Also, are you sure that a calcout record followed by a sequence record would be inadequate?
When I first read your message I thought that you had ruled this out, but now I think that you mean that you don't want a SNC/SNL program.
On Apr 10, 2010, at 5:06 AM, Silver wrote:
> hi,
> My case is like this:
> 1. I can get a waveform value from one PV.
> 2. After gaining the value, it will FLNK a subroutine record. then I want to do come caculation in subroutine record, such as caculating the steps which motor need move.
> 3. to drive the motor, I will first set an ao record (motor:steps) a value, than set a bo record (motor:move) to run the motor.
> I have used the subroutine/gensub record before, but I don't know how to drive the other record in it, use dbCaPutLink? Where can I find detailed examples? Can anyone help me? thank a lot for your help.
> Ps, as I need to set the steps of motor differently each time, so can't just use FLNK in db file. Also I don't want to use Sequencer.
> #include <stdio.h>
> #include <dbDefs.h>
> #include <registryFunction.h>
> #include <subRecord.h>
> #include <epicsExport.h>
> int mySubDebug;
> typedef long (*processMethod)(subRecord *precord);
> static long mySubInit(subRecord *precord,processMethod process)
> if (mySubDebug)
> printf("Record %s called mySubInit(%p, %p)\n",
> precord->name, (void*) precord, (void*) process);
> return(0);
> static long mySubProcess(subRecord *precord)
> if (mySubDebug)
> /* printf("Record %s called mySubProcess(%p)\n",
> precord->name, (void*) precord);*/
> printf("Record %s called mySubProcess(%p),VAL=%f\n",precord->name, (void*) precord, (precord->a/123.456));
> return(0);
> /* Register these symbols for use by IOC code: */
> epicsExportAddress(int, mySubDebug);
> epicsRegisterFunction(mySubInit);
> epicsRegisterFunction(mySubProcess);
> Best regards
> Geyang 2010-04-10
Eric Norum
[email protected]
- how to process other records in subroutine record by ca link? Silver
Re: how to process other records in subroutine record by ca link? Eric Norum
Computer Control Specialist position at the ANU Dimitrios Tsifakis
<2010>
2025
2026
<2010>
2025
2026
