Hello,
I have met problem when I build IOC, following is the result of running the
IOC.
#!../../bin/linux-x86/ddc ##
You may have to change ddc to something else ## everywhere it appears in this
file <
envPaths epicsEnvSet(ARCH,"linux-x86") epicsEnvSet(IOC,"iocddc") epicsEnvSet(TOP,"/home/lailw/epics_ioc/board_user_mod") epicsEnvSet(EPICS_BASE,"/epics/base") cd
/home/lailw/epics_ioc/board_user_mod ## Register all support
components dbLoadDatabase("dbd/ddc.dbd") Error: record type not
found Parsing ')' in file dbd/ddc.dbd line 1 db_parse
returned -1 ddc_registerRecordDeviceDriver(pdbbase) ## Load record
instances dbLoadTemplate
"db/userHost.substitutions" filename="../dbLexRoutines.c" line
number=912 Record Type does not exist dbFindRecordTypeError. Parsing
')' in file db/dbExample1.db line 1 db_parse returned
-1 filename="../dbLexRoutines.c" line number=912 Record Type does not
exist dbFindRecordTypeError. Parsing ')' in file
db/dbExample2.db line 1 db_parse returned -1 filename="../dbLexRoutines.c"
line number=912 Record Type does not exist dbFindRecordTypeError. Parsing
')' in file db/dbExample2.db line 1 db_parse returned
-1 dbLoadRecords("db/dbSubExample.db","user=lailwHost") filename="../dbLexRoutines.c"
')' in file db/dbSubExample.db line 3 db_parse returned
-1 ## Set this to see messages from mySub #var mySubDebug 1 cd
/home/lailw/epics_ioc/board_user_mod/iocBoot/iocddc iocInit() Starting
iocInit ############################################################################ ##
EPICS R3.14.9 $R3-14-9$ $2007/02/05 16:31:45$ ## EPICS Base built Jan 1
2010 ############################################################################ Thread
_main_ (0x9bb3098) can't proceed, suspending.
I have tried many times, but this problem always displayed.
Any idea how to fix it?
Thanks.
2010-04-14
lailongwei
- RE: The problem of building IOC Mark Rivers
Re: INP field length Dirk Zimoch
<2010>
2025
2026
asyn R4-13 available Mark Rivers
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
