It appears that your ddc.dbd file is incorrect. The problem is probably in how you built that dbd file in your application.
Sent: Tue 4/13/2010 10:19 PM
To: tech-talk
Subject: The problem of building IOC
Hello, I have met problem when I build IOC, following is the result of running the IOC.
#!../../bin/linux-x86/ddc
## You may have to change ddc to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocddc")
epicsEnvSet(TOP,"/home/lailw/epics_ioc/board_user_mod")
epicsEnvSet(EPICS_BASE,"/epics/base")
cd /home/lailw/epics_ioc/board_user_mod
dbLoadDatabase("dbd/ddc.dbd")
Error: record type not found
Parsing ')'
in file dbd/ddc.dbd line 1
db_parse returned -1
ddc_registerRecordDeviceDriver(pdbbase)
## Load record instances
dbLoadTemplate "db/userHost.substitutions"
filename="../dbLexRoutines.c" line number=912
Record Type does not exist dbFindRecordTypeError.
Parsing ')'
in file db/dbExample1.db line 1
Parsing ')'
in file db/dbExample2.db line 1
Parsing ')'
Parsing ')'
dbLoadRecords("db/dbSubExample.db","user=lailwHost")
Parsing ')'
in file db/dbSubExample.db line 3
## Set this to see messages from mySub
#var mySubDebug 1
cd /home/lailw/epics_ioc/board_user_mod/iocBoot/iocddc
iocInit()
Starting iocInit
## EPICS R3.14.9 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Jan 1 2010
Thread _main_ (0x9bb3098) can't proceed, suspending.
I have tried many times, but this problem always displayed.
Any idea how to fix it?
Thanks.
2010-04-14
lailongwei
- The problem of building IOC lailongwei
writing to aao crashes ioc Dirk Zimoch
<2010>
2025
2026
<2010>
2025
2026
