When an aao is written by an other record, the ioc crashes. The problem seems to independent of the DTYP of the aao. I used an (unofficial) Soft Channel support (attached). Example db: record (aao, "aao1")
field (FTVL, "DOUBLE")
field (NELM, "10")
field (OUT, "aao2")
}record (aao, "aao2")
field (NELM, "10")
}record (ao, "ao1")
field (OUT, "aao2")
}When I write aao1 or ao1 the IOC crashes. (Note that aao2 is not even processed in that case.) If I write directly into aao2 there is no problem. Any idea? I am using EPICS R3.14.8.2. Dirk /*************************************************************************\
* Copyright (c) 2003 SLS Swiss Light Source
* based upon waveform support
* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
* National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
* EPICS BASE Versions 3.13.7
* and higher are distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
/* devAaoSoft.c */
/* devAaoSoft.c - Device Support Routines for soft Waveform Records*/
* Original Author: Bob Dalesio
* Current Author: Dirk Zimoch
* Date: 11-JUL-2003
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "alarm.h"
#include "dbDefs.h"
#include "dbAccess.h"
#include "recGbl.h"
#include "recSup.h"
#include "devSup.h"
#include "link.h"
#include "aaoRecord.h"
#include "epicsExport.h"
/* Create the dset for devAaoSoft */
static long init_record();
static long write_aao();
struct {
long number;
DEVSUPFUN report;
DEVSUPFUN init;
DEVSUPFUN init_record;
DEVSUPFUN get_ioint_info;
DEVSUPFUN read_aao;
} devAaoSoft = {
5,
NULL,
NULL,
init_record,
NULL,
write_aao
epicsExportAddress(dset,devAaoSoft);
static int sizeofTypes[] = {MAX_STRING_SIZE,1,1,2,2,4,4,4,8,2};
static long init_record(aaoRecord *paao)
/* aao record does not allocate bptr. Why not? */
if (!paao->bptr) {
if(paao->ftvl>DBF_ENUM) paao->ftvl=2;
paao->bptr = (char *)calloc(paao->nelm,sizeofTypes[paao->ftvl]);
/* aao.out must be a CONSTANT or a PV_LINK or a DB_LINK or a CA_LINK*/
switch (paao->out.type) {
case (CONSTANT) :
paao->nord = 0;
break;
case (PV_LINK) :
case (DB_LINK) :
case (CA_LINK) :
break;
default :
recGblRecordError(S_db_badField,(void *)paao,
"devAaoSoft (init_record) Illegal INP field");
return(S_db_badField);
return(0);
static long write_aao(aaoRecord *paao)
long status,nRequest;
nRequest=paao->nelm;
/* aao record can not handle simulation mode. Why not? */
if (paao->simm == YES){
"devAaoSoft (read_aao) simulation mode unsupported");
status = dbPutLink(&paao->out,paao->ftvl,paao->bptr, nRequest);
/*If dbGetLink got no values leave things as they were*/
if(nRequest>0) paao->nord = nRequest;
return(0);
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
