Dirk, I was seeing something similar (though in 3.14.11),
and "dbpr <recordname>,5" showed "DTYP: <nil>",
until I added the line
device(aao,CONSTANT,devAaoSoft,"Soft Channel")
to the .dbd file.
Tim
Dirk Zimoch wrote:
Hi all,
When an aao is written by an other record, the ioc crashes. The
problem seems to independent of the DTYP of the aao. I used an
(unofficial) Soft Channel support (attached).
Example db:
record (aao, "aao1")
field (FTVL, "DOUBLE")
field (NELM, "10")
field (OUT, "aao2")
record (aao, "aao2")
field (NELM, "10")
record (ao, "ao1")
field (OUT, "aao2")
When I write aao1 or ao1 the IOC crashes. (Note that aao2 is not even
processed in that case.) If I write directly into aao2 there is no
problem.
Any idea?
I am using EPICS R3.14.8.2.
Dirk
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group (www.aps.anl.gov/aod/bcda)
Advanced Photon Source, Argonne National Lab
- Re: writing to aao crashes ioc Dirk Zimoch
- writing to aao crashes ioc Dirk Zimoch
Re: Asyn Question Eric Norum
A Rudimentary EDL to SVG converter Kevin Anderson
<2010>
2025
2026
<2010>
2025
2026
