1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn Question
To: "Szalata, Zenon M." <[email protected]>
Cc: TECHTALK Tech-Talk <[email protected]>
Date: Thu, 15 Apr 2010 12:17:33 -0700
Could you not just have 32 ports?
drvAsynIPPortConfigure("L01","192.168.1.1:1255 UDP",0,0,0)
drvAsynIPPortConfigure("L02","192.168.1.2:1255 UDP",0,0,0)
drvAsynIPPortConfigure("L03","192.168.1.3:1255 UDP",0,0,0)
On Apr 15, 2010, at 12:07 PM, Szalata, Zenon M. wrote:
> I am designing a soft IOC to run on Linux, which will control and monitor an array of 32 identical network (Ethernet) devices.  The network protocol is udp.  I will use asyn and most likely streamDevice.  What is the most sensible approach to implement this?
> The IOC needs to communicate with all devices present, each with a unique IP address.  My uncertainty is how to establish communication with and then address each device as needed.  Also how to maintain a list of connections.
> Is there an example of similar implementation?
> I have written a number of soft IOCs to communicate with a single Ethernet device using asyn.  Dealing with an array of Ethernet devices seems daunting.
> Any suggestions are welcome,
> Zen
Eric Norum
[email protected]
RE: Asyn Question Szalata, Zenon M.
Prev: Asyn Question Szalata, Zenon M.
Next: Re: writing to aao crashes ioc Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Asyn Question Szalata, Zenon M.
