1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: epicsThreadOnceOsd epicsMutexLock failed
To: <[email protected]>
Cc: Panepucci Ezequiel <[email protected]>, Ebner Simon <[email protected]>
Date: Fri, 16 Apr 2010 16:08:53 +0200
When CA client exit, sometimes it spills out "epicsThreadOnceOsd
epicsMutexLock failed" message. It has been reported since 3.14.7 and
has an entry 207 in Mantis. The status is labeled as "suspended". Does
it mean it is hopeless to be solved?
http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=207
In normal cases it is harmless since the program is anyway exiting.
However it exits with code 255. If it is run as a subprocess, this will
cause the caller think exit code other than 0 is wrong and stop
execution. In such case one cannot ignore the exit code, which would
ignore other possible exceptions.
Thanks and nice weekend.
Dr. Xiaoqiang Wang
Paul Scherrer Institut, WBGB/010
5232 Villigen PSI, Switzerland
Re: epicsThreadOnceOsd epicsMutexLock failed Ralph Lange
Prev: How to compile the sysVmeMapShow() function to the MVME5500 BSP? 周永年
Next: Re: epicsThreadOnceOsd epicsMutexLock failed Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to compile the sysVmeMapShow() function to the MVME5500 BSP? Andrew Johnson
