Hello Xiaoqiang,
Please note that the EPICS Base bug tracker has been moved to the new
EPICS Base location on Lauchpad, this bug is now:
https://bugs.launchpad.net/epics-base/+bug/541249
The old Mantis tracker is still on-line for reference, but it is *not*
updated anymore.
The bug is suspended, because Jeff was asking for a stack trace which
was never provided.
The bug is about erroneous behavior experienced on the HP-UX operating
system.
Support for HP-UX has been dropped with EPICS release 3.14.9, so this
bug will most probably never be fixed.
If you experience the error on a different version of EPICS and a
different operating system, please check on Launchpad if it has been
reported. If not, you are encouraged to file a new bug report.
Thanks a lot,
Ralph
On Fri 16 Apr 2010 10:08:53 Wang Xiaoqiang wrote:
When CA client exit, sometimes it spills out "epicsThreadOnceOsd
epicsMutexLock failed" message. It has been reported since 3.14.7 and
has an entry 207 in Mantis. The status is labeled as "suspended". Does
it mean it is hopeless to be solved?
http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=207
In normal cases it is harmless since the program is anyway exiting.
However it exits with code 255. If it is run as a subprocess, this will
cause the caller think exit code other than 0 is wrong and stop
execution. In such case one cannot ignore the exit code, which would
ignore other possible exceptions.
Thanks and nice weekend.
Dr. Xiaoqiang Wang
Paul Scherrer Institut, WBGB/010
5232 Villigen PSI, Switzerland
- RE: epicsThreadOnceOsd epicsMutexLock failed nick.rees
- epicsThreadOnceOsd epicsMutexLock failed Wang Xiaoqiang
<2010>
2025
2026
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
