Hi Dave,
StreamDevice sets record to INVALID state when there was a communication
problem (timeout, errors reported from asynDriver, parsing errors).
Whenever the device support is not able to fetch the valid value from
the hardware the record becomes INVALID to signal that the value is not
trustworthy. The STAT field and probably error messages on the IOC will
tell you more about the reason.
This should not break the processing chain. The ai record should have
finished its processing being INVALID and processing should continue
with the FLNK, monitors, etc.
Normally the record recovers when the record is processed the next time
and the hardware sends a value. How do you process the ai record? It may
help if you describe your processing chain.
An input record has no IVOA field because it does not do any output
actions. To do something similar you can read the value with an ao or
calcout record with MS in the input link (DOL or INPA) and use IVOA of
that record. It depends on what you want to do in case reading the value
fails.
Best regards,
Dirk
Dave Reid wrote:
I have a database that communicates via RS-232 to a vacuum gauge
controller. I do this by setting up an Analog In record, that has the
DTYP set to "stream". These Analog In records are part of a processing
chain in the database.
What happens is that one of my AI records goes into the "Invalid" alarm
state, and this breaks the processing chain, and the only way we have
been able to recover from this is to reboot the IOC.
So the questions are:
1-Why are we getting into this alarm state? Is this something that the
stream device support is doing?
2-How does one recover gracefully from an "Invalid" alarm state?
3-Why is there not an "IVOA" field for input records?
Thanks....
dave
- Analog Input records, Stream Device, and INVALID Alarms Dave Reid
Re: writing to aao crashes ioc Dirk Zimoch
Re: writing to aao crashes ioc Benjamin Franksen
<2010>
2025
2026
Asyn Question Szalata, Zenon M.
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
