Is there a recommended replacement for StripTool on 64-bit?
If so what is it?
E
On 13:25 Thu 22 Apr , Janet Anderson wrote:
> Yes, it looks like the axis code in StripTool might need major changes.
> I am looking at the code now to
> see what needs to be done.
> Janet
> Kevin Anderson wrote:
>> By far the best solution is indeed to compile a 32-bit version (one way or another). It will run perfectly on a 64-bit machine.
- Re: Striptool crashes for Fedora 11 64 bit version... Ralph Lange
- Re: Striptool crashes for Fedora 11 64 bit version... Andrew Johnson
- RE: Striptool crashes for Fedora 11 64 bit version... Kevin Anderson
- Re: Striptool crashes for Fedora 11 64 bit version... Janet Anderson
RE: gateway won't set "busy" PV type properly Mark Rivers
<2010>
2025
2026
<2010>
2025
2026
