1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: çå: hi, how to use burtrb to save status as a task?
To: [email protected]
Date: Wed, 28 Apr 2010 11:06:14 +0200
On Wednesday 28 April 2010, æåè wrote:
> Thanks for your reply. I am sorry for my careless. I did use the request
>  file in the script "burtrb -f 17U-all.req -l name.log -o name.snap" and
>  there are no #autosave. I am sorry again. The script is executed but
>  only the first value is recorded. While executing the script directly,
>  all the value is saved.
Hm, maybe you have set EPICS_CA_AUTO_ADDR_LIST or EPICS_CA_ADDR_LIST in your
interactive shell environment? Note that cron (necessarily) starts its jobs
with a fresh (and non-interactive) environment under a /bin/sh. It could be
/bin/sh is not bash, but a simpler shell like dash (this is the case with
newer versions of ubuntu, for instance). Thus /bin/sh might not read
~/.bashrc. It _does_ read ~/.profile if it exists, though.
Cheers
Ben
> The request file content is below:
> %17U Ion chamber
> 17U:ES:ADC-01.VAL
> %17U Energy
> X17U1:OP:Mono:Soft_bragg.VAL
> %17U XBPM position
> X17U1:FE:XBPM1:POS:X
> X17U1:FE:XBPM1:POS:Y
> %17U SLIT1
> X17U1:OP:SLIT1:size_x.RBV
> X17U1:OP:SLIT1:center_x.RBV
> X17U1:OP:SLIT1:size_y.RBV
> X17U1:OP:SLIT1:center_y.RBV
> %17U T2
> X17U1:OP:Mono:T2.RBV
> %17U Piezo
> X17U1:E621:GET_SERVO
> X17U1:E621:PUT_VOL
> X17U1:E621:GET_VOL
> The snap file is:
> --- Start BURT header
> Time:     Wed Apr 28 15:30:04 2010
> Login ID: mx ()
> Eff  UID: 501
> Group ID: 500
> Keywords:
> Comments:
> Type:     Absolute
> Directory /home/mx/beamstatus
> Req File: 17U-all.req
> --- End BURT header
> 17U:ES:ADC-01.VAL 1 -9.159466308435188e-04
> The log file is:
> X17U1:OP:Mono:Soft_bragg.VAL ... not connected so no
>  ca_array_get_callback() X17U1:FE:XBPM1:POS:X ... not connected so no
>  ca_array_get_callback() X17U1:FE:XBPM1:POS:Y ... not connected so no
>  ca_array_get_callback() X17U1:OP:SLIT1:size_x.RBV ... not connected so
>  no ca_array_get_callback() X17U1:OP:SLIT1:center_x.RBV ... not connected
>  so no ca_array_get_callback() X17U1:OP:SLIT1:size_y.RBV ... not
>  connected so no ca_array_get_callback() X17U1:OP:SLIT1:center_y.RBV ...
>  not connected so no ca_array_get_callback() X17U1:OP:Mono:T2.RBV ... not
>  connected so no ca_array_get_callback() X17U1:E621:GET_SERVO ... not
>  connected so no ca_array_get_callback() X17U1:E621:PUT_VOL ... not
>  connected so no ca_array_get_callback() X17U1:E621:GET_VOL ... not
>  connected so no ca_array_get_callback() X17U1:OP:SLIT2:size_x.RBV ...
>  not connected so no ca_array_get_callback() X17U1:OP:SLIT2:center_x.RBV
>  ... not connected so no ca_array_get_callback()
>  X17U1:OP:SLIT2:size_y.RBV ... not connected so no
>  ca_array_get_callback() X17U1:OP:SLIT2:center_y.RBV ... not connected so
>  no ca_array_get_callback() X17U1:OP:M1:Soft_z.RBV ... not connected so
>  no ca_array_get_callback( .......
> -----éäåä-----
> åää: [email protected] [mailto:[email protected]]
>  äè Pete R. Jemian åéæé: 2010å4æ28æ 15:09
> æää: [email protected]
> äé: Re: hi, how to use burtrb to save status as a task?
> You do not show a BURT request file that contains the list of PVs you
> wish to record.  Name the request file with something like this:
> Pathtoburtrb  -f requestFile.req ïl name.log ïo name.snap
> Also, the first two lines in your script should be swapped:
> #!/bin/bash
> #autosave
> On 4/27/2010 11:30 PM, æåè wrote:
> > Hello, I write a shell script which use burtrb to save the beamline
> > status every an hour. When I execute the script, it is ok. But I add it
> > as a task by crontab, there always connect failed.
> > The shell script just like:
> > #autosave
> > #!/bin/bash
> > Cd pathtosavedata
> > #create the snap file name
> > â
> > â
> > Pathtoburtrb ïl name.log ïo name.snap
> > Chmod a+x autosave
> > The crontab like below:
> > 30 * * * * user pathtoautosave
> > It did execute the task, but it always failed to connect to pv expect
> > the first one, even I use the parameter ïr 10. Please help me figure
> > out the problem.
> > Thanks very much.
Benjamin Franksen
Control System Group
Elektronenspeicherring BESSY II
Albert-Einstein-Str. 15, 12489 Berlin
Fon +49 30 6392 4982
Fax +49 30 6392 4859
[email protected]
答复: hi, how to use burtrb to save status as a task? 汪启胜
Prev: 答复: hi, how to use burtrb to save status as a task? 汪启胜
Next: çå: çå: hi,how to use burtrb to save status as a task? æåè
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
