1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem Building SNC/SEQ Module
To: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Thu, 29 Apr 2010 14:35:20 -0500
Your error is a missing library, fl, which I believe is the "flex" library.  That suggests you need to install "flex".  But I did not think EPICS required that, since one does not need to install flex on Windows, for example.
I'm not sure why this is happening.
From: [email protected] on behalf of Pawel Kowalski - BiRa Systems Inc.
Sent: Thu 4/29/2010 2:20 PM
To: 'EPICS tech-talk'
Subject: Problem Building SNC/SEQ Module
Hello,
I am trying to set up a new epics installation on a openSuse 11 system. I got epics base to compile fine. However, when I try to compile SNC/SEQ is get errors. I attached a log file, any help would be appreciated. Also, is there a standard convention for where to place modules in relation to base? Currently my directory structure looks like this:
/home/<user>/epics/
/home/<user>/epics/base
/home/<user>/epics/modules/sncseq
Not sure if this is correct (or if it matters). Thank you in advance.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com <http://www.bira.com/>
Phone:                   505-881-8887
Fax:                       505-888-0651
Address:                2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
Problem Building SNC/SEQ Module Pawel Kowalski - BiRa Systems Inc.
Prev: Problem Building SNC/SEQ Module Pawel Kowalski - BiRa Systems Inc.
Next: RE: Problem Building SNC/SEQ Module Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
