Subject: |
Problem Building SNC/SEQ Module |
"Pawel Kowalski - BiRa Systems Inc." <[email protected]> |
To: |
"'EPICS tech-talk'" <[email protected]> |
Date: |
Thu, 29 Apr 2010 13:20:41 -0600 |
Hello,
I am trying to set up a new epics installation on a openSuse
11 system. I got epics base to compile fine. However, when I try to compile SNC/SEQ
is get errors. I attached a log file, any help would be appreciated. Also, is
there a standard convention for where to place modules in relation to base?
Currently my directory structure looks like this:
/home/<user>/epics/
/home/<user>/epics/base
/home/<user>/epics/modules/sncseq
Not sure if this is correct (or if it matters). Thank you in
advance.
Pawel
Kowalski
BiRa
Systems Inc.
www.bira.com
Phone: 505-881-8887
Fax: 505-888-0651
Address: 2410
Midtown PL NE
STE A
Albuquerque NM
87107 USA
linux-wsk6:~/epics/modules/sncseq # make clean install
make -C ./configure clean
make[1]: Entering directory `/root/epics/modules/sncseq/configure'
rm -rf O.linux-x86 O.Common
make[1]: Leaving directory `/root/epics/modules/sncseq/configure'
make -C ./src clean
make[1]: Entering directory `/root/epics/modules/sncseq/src'
make -C ./pv clean
make[2]: Entering directory `/root/epics/modules/sncseq/src/pv'
make[2]: Leaving directory `/root/epics/modules/sncseq/src/pv'
make -C ./seq clean
make[2]: Entering directory `/root/epics/modules/sncseq/src/seq'
make[2]: Leaving directory `/root/epics/modules/sncseq/src/seq'
make -C ./dev clean
make[2]: Entering directory `/root/epics/modules/sncseq/src/dev'
make[2]: Leaving directory `/root/epics/modules/sncseq/src/dev'
make -C ./snc clean
make[2]: Entering directory `/root/epics/modules/sncseq/src/snc'
make[2]: Leaving directory `/root/epics/modules/sncseq/src/snc'
make[1]: Leaving directory `/root/epics/modules/sncseq/src'
make -C ./test clean
make[1]: Entering directory `/root/epics/modules/sncseq/test'
make -C ./simple clean
make[2]: Entering directory `/root/epics/modules/sncseq/test/simple'
make[2]: Leaving directory `/root/epics/modules/sncseq/test/simple'
make -C ./validate clean
make[2]: Entering directory `/root/epics/modules/sncseq/test/validate'
make[2]: Leaving directory `/root/epics/modules/sncseq/test/validate'
make -C ./demo clean
make[2]: Entering directory `/root/epics/modules/sncseq/test/demo'
make[2]: Leaving directory `/root/epics/modules/sncseq/test/demo'
make[1]: Leaving directory `/root/epics/modules/sncseq/test'
make -C ./configure install
perl /root/epics/base/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
`/root/epics/modules/sncseq/configure/O.linux-x86'
perl /root/epics/base/bin/linux-x86/convertRelease.pl checkRelease
make -C ./src install
make -C ./pv install
perl /root/epics/base/bin/linux-x86/makeMakefile.pl O.linux-x86 ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory
`/root/epics/modules/sncseq/src/pv/O.linux-x86'
Installing generic include file ../../../include/pv.h
mkdir ../../../include
Installing generic include file ../../../include/pvAlarm.h
Installing generic include file ../../../include/pvCa.h
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -DPVCA -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -O3 -Wall -m32 -g -fPIC -I. -I../O.Common -I.
-I.. -I../../../include/os/Linux -I../../../include
-I/root/epics/base/include/os/Linux -I/root/epics/base/include
../pvNew.cc
../pv.cc
../pvCa.cc
/usr/bin/ar -rc libpv.a pvNew.o pv.o pvCa.o
/usr/bin/ranlib libpv.a
/usr/bin/g++ -o libpv.so -shared -fPIC -Wl,-hlibpv.so
-L/root/epics/base/lib/linux-x86 -Wl,-rpath,/root/epics/base/lib/linux-x86
-m32 pvNew.o pv.o pvCa.o -lca -lCom -lpthread
-lreadline -lncurses -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libpv.so
mkdir ../../../lib
mkdir ../../../lib/linux-x86
Installing library ../../../lib/linux-x86/libpv.a
/usr/bin/ranlib ../../../lib/linux-x86/libpv.a
make[3]: Leaving directory `/root/epics/modules/sncseq/src/pv/O.linux-x86'
make -C ./seq install
mkdir O.Common
`/root/epics/modules/sncseq/src/seq/O.linux-x86'
Installing generic include file ../../../include/seqCom.h
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
../seq_main.c
../seq_task.c
../seq_task.c: In function ?sequencer?:
../seq_task.c:122: warning: call to function ?ss_entry? without a real prototype
../seq_task.c:81: note: ?ss_entry? was declared here
../seq_ca.c
../seq_if.c
../seq_mac.c
../seq_prog.c
../seq_qry.c
rm -f seqVersion.c
perl ../seqVersion.pl 2.0.12 > seqVersion.c
seqVersion.c
../seqCommands.c
/usr/bin/ar -rc libseq.a seq_main.o seq_task.o seq_ca.o seq_if.o
seq_mac.o seq_prog.o seq_qry.o seqVersion.o seqCommands.o
/usr/bin/ranlib libseq.a
/usr/bin/g++ -o libseq.so -shared -fPIC -Wl,-hlibseq.so
-L/root/epics/modules/sncseq/lib/linux-x86 -L/root/epics/base/lib/linux-x86
-Wl,-rpath,/root/epics/modules/sncseq/lib/linux-x86
-Wl,-rpath,/root/epics/base/lib/linux-x86 -m32
seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o
seqVersion.o seqCommands.o -lpv -lCom -lpthread -lreadline -lncurses
-lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libseq.so
Installing library ../../../lib/linux-x86/libseq.a
/usr/bin/ranlib ../../../lib/linux-x86/libseq.a
make -C ./dev install
mkdir O.Common
`/root/epics/modules/sncseq/src/dev/O.linux-x86'
Installing dbd file ../../../dbd/devSequencer.dbd
mkdir ../../../dbd
-D_REENTRANT -O3 -Wall -I../../seq -m32 -g -fPIC -I.
-I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include
../devSequencer.c
../devSequencer.c: In function ?seqShowScanPvtInit?:
../devSequencer.c:191: warning: comparison between pointer and integer
../devSequencer.c:198: warning: comparison between pointer and integer
../devSequencer.c:199: warning: assignment makes integer from pointer
without a cast
/usr/bin/ar -rc libseqDev.a devSequencer.o
/usr/bin/ranlib libseqDev.a
/usr/bin/g++ -o libseqDev.so -shared -fPIC -Wl,-hlibseqDev.so
devSequencer.o -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc
-ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
-lpthread -lreadline -lncurses -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libseqDev.so
Installing library ../../../lib/linux-x86/libseqDev.a
/usr/bin/ranlib ../../../lib/linux-x86/libseqDev.a
make -C ./snc install
mkdir O.Common
`/root/epics/modules/sncseq/src/snc/O.linux-x86'
-D_REENTRANT -O3 -Wall -m32 -g -I. -I../O.Common -I. -I..
../snc_main.c
../snc_main.c: In function ?main?:
../snc_main.c:90: warning: call to function ?get_args? without a real prototype
../snc_main.c:58: note: ?get_args? was declared here
../snc_main.c: In function ?get_args?:
../snc_main.c:158: warning: call to function ?get_in_file? without a real
prototype
../snc_main.c:60: note: ?get_in_file? was declared here
../snc_main.c:163: warning: call to function ?get_out_file? without a real
prototype
../snc_main.c:61: note: ?get_out_file? was declared here
../snc_main.c:167: warning: call to function ?get_options? without a real
prototype
../snc_main.c:59: note: ?get_options? was declared here
../parse.c
../parse.c: In function ?decl_stmt?:
../parse.c:135: warning: call to function ?findVar? without a real
prototype
../parse.h:87: note: ?findVar? was declared here
../parse.c: In function ?assign_single?:
../parse.c:212: warning: call to function ?findVar? without a real
prototype
../parse.c:229: warning: call to function ?build_db_struct? without a real
prototype
../parse.c:69: note: ?build_db_struct? was declared here
../parse.c: In function ?assign_subscr?:
../parse.c:255: warning: call to function ?findVar? without a real
prototype
../parse.c:274: warning: call to function ?build_db_struct? without a real
prototype
../parse.c:293: warning: call to function ?alloc_db_lists? without a real
prototype
../parse.c:70: note: ?alloc_db_lists? was declared here
../parse.c: In function ?assign_list?:
../parse.c:328: warning: call to function ?findVar? without a real
prototype
../parse.c:352: warning: call to function ?build_db_struct? without a real
prototype
../parse.c:355: warning: call to function ?alloc_db_lists? without a real
prototype
../parse.c: In function ?build_db_struct?:
../parse.c:385: warning: call to function ?addChan? without a real
prototype
../parse.c:72: note: ?addChan? was declared here
../parse.c: In function ?monitor_stmt?:
../parse.c:446: warning: call to function ?findVar? without a real
prototype
../parse.c: In function ?sync_stmt?:
../parse.c:515: warning: call to function ?findVar? without a real
prototype
../parse.c:532: warning: call to function ?findVar? without a real
prototype
../parse.c: In function ?syncq_stmt?:
../parse.c:589: warning: call to function ?findVar? without a real
prototype
../parse.c:614: warning: call to function ?findVar? without a real
prototype
../parse.c: In function ?defn_c_stmt?:
../parse.c:676: warning: call to function ?link_expr? without a real prototype
../parse.h:86: note: ?link_expr? was declared here
../phase2.c
../phase2.c: In function ?gen_preamble?:
../phase2.c:155: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:56: note: ?gen_opt_defn? was declared here
../phase2.c:156: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:157: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:158: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:159: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:160: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c: In function ?connect_variable?:
../phase2.c:250: warning: call to function ?findVar? without a real
prototype
../phase2.c: In function ?gen_defn_c_code?:
../phase2.c:432: warning: format ?%s? expects type ?char *?, but argument
2 has type ?struct expression *?
../phase2.c: In function ?gen_global_c_code?:
../phase2.c:450: warning: format ?%s? expects type ?char *?, but argument
../gen_ss_code.c
../gen_ss_code.c: In function ?gen_action_func?:
../gen_ss_code.c:302: warning: format ?%s? expects type ?char *?, but
argument 2 has type ?struct expression *?
../gen_ss_code.c: In function ?eval_expr?:
../gen_ss_code.c:569: warning: format ?%s? expects type ?char *?, but
../gen_ss_code.c: In function ?gen_ef_func?:
../gen_ss_code.c:728: warning: call to function ?findVar? without a real
prototype
../gen_ss_code.c: In function ?gen_pv_func?:
../gen_ss_code.c:792: warning: call to function ?findVar? without a real
prototype
../gen_ss_code.c:800: warning: call to function ?findVar? without a real
prototype
../gen_ss_code.c:769: warning: ?ep3? may be used uninitialized in this function /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
../gen_tables.c
../gen_tables.c: In function ?gen_db_blocks?:
../gen_tables.c:112: warning: call to function ?fill_db_block? without a
real prototype
../gen_tables.c:42: note: ?fill_db_block? was declared here
../gen_tables.c:119: warning: call to function ?fill_db_block? without a
real prototype
../gen_tables.c: In function ?fill_db_block?:
../gen_tables.c:194: warning: call to function ?db_type_str? without a
real prototype
../gen_tables.c:144: note: ?db_type_str? was declared here
../gen_tables.c: In function ?gen_state_blocks?:
../gen_tables.c:263: warning: call to function ?eval_state_event_mask?
../gen_tables.c:49: note: ?eval_state_event_mask? was declared here
../gen_tables.c:278: warning: call to function ?fill_state_block? without
a real prototype
../gen_tables.c:44: note: ?fill_state_block? was declared here
../gen_tables.c: In function ?gen_ss_array?:
../gen_tables.c:540: warning: call to function ?find_error_state? without
a real prototype
../gen_tables.c:53: note: ?find_error_state? was declared here
/root/epics/base/bin/linux-x86/e_flex
-S/root/epics/base/include/flex.skel.static -8 -I ../snc_lex.l
mv lex.yy.c snc_lex.c
rm -f snc.c y.tab.c
rm -f snc.h y.tab.h
/root/epics/base/bin/linux-x86/antelope -d -v ../snc.y
/root/epics/base/bin/linux-x86/antelope: 474 shift/reduce conflicts, 270
reduce/reduce conflicts.
mv y.tab.c snc.c
mv y.tab.h snc.h
-I/root/epics/base/include/os/Linux -I/root/epics/base/include snc.c
In file included from ../snc.y:476:
../snc_lex.l: In function ?yy_get_next_buffer?:
../snc_lex.l:446: warning: implicit declaration of function ?read?
y.tab.c: In function ?yyparse?:
y.tab.c:1100: warning: implicit declaration of function ?yyerror?
../snc.y:113: warning: implicit declaration of function ?program?
../snc.y:117: warning: implicit declaration of function ?snc_err?
../snc.y:121: warning: implicit declaration of function ?program_name?
../snc.y:144: warning: implicit declaration of function ?assign_single?
../snc.y:146: warning: implicit declaration of function ?assign_subscr?
../snc.y:149: warning: implicit declaration of function ?assign_list?
../snc.y:153: warning: call to function ?expression? without a real
prototype
../parse.h:86: note: ?expression? was declared here
../snc.y:155: warning: call to function ?expression? without a real
prototype
../snc.y:155: warning: call to function ?link_expr? without a real
prototype
../snc.y:164: warning: implicit declaration of function ?monitor_stmt?
../snc.y:173: warning: implicit declaration of function ?set_debug_print?
../snc.y:179: warning: implicit declaration of function ?decl_stmt?
../snc.y:202: warning: call to function ?expression? without a real
prototype
../snc.y:204: warning: call to function ?expression? without a real
prototype
../snc.y:224: warning: implicit declaration of function ?sync_stmt?
../snc.y:229: warning: implicit declaration of function ?syncq_stmt?
../snc.y:239: warning: implicit declaration of function ?defn_c_stmt?
../snc.y:243: warning: implicit declaration of function ?option_stmt?
../snc.y:249: warning: call to function ?link_expr? without a real
prototype
../snc.y:254: warning: call to function ?expression? without a real
prototype
../snc.y:256: warning: implicit declaration of function ?entry_code?
../snc.y:258: warning: implicit declaration of function ?exit_code?
../snc.y:265: warning: call to function ?link_expr? without a real
prototype
../snc.y:271: warning: call to function ?expression? without a real
prototype
../snc.y:279: warning: call to function ?link_expr? without a real
prototype
../snc.y:285: warning: call to function ?expression? without a real
prototype
../snc.y:287: warning: call to function ?expression? without a real
prototype
../snc.y:293: warning: call to function ?link_expr? without a real
prototype
prototype
../snc.y:300: warning: call to function ?link_expr? without a real
prototype
../snc.y:306: warning: call to function ?link_expr? without a real
prototype
../snc.y:311: warning: call to function ?expression? without a real
prototype
../snc.y:317: warning: call to function ?expression? without a real
prototype
../snc.y:323: warning: call to function ?link_expr? without a real
prototype
../snc.y:329: warning: call to function ?expression? without a real
prototype
../snc.y:337: warning: call to function ?expression? without a real
prototype
../snc.y:338: warning: call to function ?expression? without a real
prototype
../snc.y:339: warning: call to function ?expression? without a real
prototype
../snc.y:340: warning: call to function ?expression? without a real
prototype
../snc.y:341: warning: call to function ?expression? without a real
prototype
../snc.y:342: warning: call to function ?expression? without a real
prototype
../snc.y:343: warning: call to function ?expression? without a real
prototype
../snc.y:344: warning: call to function ?expression? without a real
prototype
../snc.y:345: warning: call to function ?expression? without a real
prototype
../snc.y:346: warning: call to function ?expression? without a real
prototype
../snc.y:347: warning: call to function ?expression? without a real
prototype
../snc.y:348: warning: call to function ?expression? without a real
prototype
../snc.y:349: warning: call to function ?expression? without a real
prototype
../snc.y:350: warning: call to function ?expression? without a real
prototype
../snc.y:351: warning: call to function ?expression? without a real
prototype
../snc.y:352: warning: call to function ?expression? without a real
prototype
../snc.y:357: warning: call to function ?link_expr? without a real
prototype
../snc.y:358: warning: call to function ?link_expr? without a real
prototype
../snc.y:414: warning: call to function ?expression? without a real
prototype
../snc.y:420: warning: call to function ?link_expr? without a real
prototype
../snc.y:426: warning: call to function ?expression? without a real
prototype
../snc.y:427: warning: call to function ?expression? without a real
prototype
../snc.y:432: warning: call to function ?expression? without a real
prototype
../snc.y:438: warning: call to function ?expression? without a real
prototype
../snc.y:442: warning: call to function ?expression? without a real
prototype
../snc.y:446: warning: call to function ?expression? without a real
prototype
../snc.y:451: warning: call to function ?expression? without a real
prototype
../snc.y:452: warning: call to function ?expression? without a real
prototype
prototype
../snc.y:456: warning: implicit declaration of function ?pp_code?
../snc.y:468: warning: implicit declaration of function ?global_c_stmt?
../snc.y:472: warning: call to function ?expression? without a real prototype
../snc.y:473: warning: call to function ?expression? without a real prototype
../snc.y:473: warning: call to function ?link_expr? without a real prototype
y.tab.c: At top level:
../snc_lex.l:554: warning: ?yyunput? defined but not used
../snc_lex.l:661: warning: ?yyrestart? defined but not used
../snc_lex.l:673: warning: ?yy_switch_to_buffer? defined but not used
../snc_lex.l:597: warning: ?input? defined but not used rm -f sncVersion.c perl ../sncVersion.pl 2.0.12 > sncVersion.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
sncVersion.c
/usr/bin/g++ -o snc -L/root/epics/base/lib/linux-x86
snc_main.o parse.o phase2.o gen_ss_code.o gen_tables.o snc.o sncVersion.o -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc-ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lfl
/usr/lib/gcc/i586-suse-linux/4.3/../../../../i586-suse-linux/bin/ld:
cannot find -lfl
collect2: ld returned 1 exit status
make[3]: *** [snc] Error 1
make[2]: *** [install.linux-x86] Error 2
make[1]: *** [snc.install] Error 2
make: *** [src.install] Error 2
- RE: Problem Building SNC/SEQ Module Mark Rivers
LabVIEW Native Channel Access for EPICS Alan Greer
<2010>
2025
2026
<2010>
2025
2026
