1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dump record fields into a text file
To: Luedeke Andreas <[email protected]>
Cc: [email protected]
Date: Fri, 30 Apr 2010 10:23:41 -0500
On Friday 30 April 2010 05:12:26 Luedeke Andreas wrote:
> Just be aware of a minor pitfall:
> if one of the fields does not exist for one of your records, it will be
> just missing in the output.
> E.g.
>     dbl * "RTYP PREC EGU DTYP DESC"
>     test:1,"bi","Soft Channel","desc of test:1"
>     test:2,"calc","1","unit","","desc of test:2"
>     test:3,"longout","unit","Soft Channel","desc of test:3"
> So if you want to parse the output, it's saver to generate extra files
> for each field that is not common to all records. (Note: 'calc' records
> have a DTYP field, it just happens to be always NIL)
(All record types must have a DTYP field, it's part of dbCommon.)
The first parameter to dbl is the record type (it doesn't actually support
wild-cards though, "*" or "" are special strings that are explicitly tested
for and mean all types), so to avoid the issue of missing fields you could
list each record type separately, giving the fields you're interested in for
that type:
    dbl bi "RTYP ZRST ONST DTYP DESC" > bi-data.txt
    dbl ai "RTYP PREC EGU DTYP DESC" > ai-data.txt
    dbl calc "RTYP PREC EGU CALC DESC" > calc-data.txt
etc.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Dump record fields into a text file Luedeke Andreas
Dump record fields into a text file emmanuel_mayssat
Re: Dump record fields into a text file Andrew Johnson
Prev: Re: Dump record fields into a text file Luedeke Andreas
Next: Re: Dump record fields into a text file Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
