1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dump record fields into a text file
Cc: [email protected]
Date: Fri, 30 Apr 2010 12:12:26 +0200
Andrew Johnson wrote on 30/04/10 00:24:
> On Thursday 29 April 2010 17:07:35 [email protected] wrote:
>> Is there a way to dump the value of records into a text file?
>> i.e. dump the value of the PREC,EGU,DTYP,DESC fields of all records?
> >From the ioc shell:
>     dbl * "PREC EGU DTYP DESC" > file.txt
> You'll have to adjust that slightly (double-quote the asterisk and add a comma
> between the arguments) if you're on vxWorks.
Just be aware of a minor pitfall:
if one of the fields does not exist for one of your records, it will be
just missing in the output.
E.g.
    dbl * "RTYP PREC EGU DTYP DESC"
    test:1,"bi","Soft Channel","desc of test:1"
    test:2,"calc","1","unit","","desc of test:2"
    test:3,"longout","unit","Soft Channel","desc of test:3"
So if you want to parse the output, it's saver to generate extra files
for each field that is not common to all records. (Note: 'calc' records
have a DTYP field, it just happens to be always NIL)
Andreas
She often gave herself very good advice (though she very seldom followed
it).
                -- Lewis Carroll
Re: Dump record fields into a text file Andrew Johnson
Dump record fields into a text file emmanuel_mayssat
Prev: Re: Dump record fields into a text file Andrew Johnson
Next: Re: Dump record fields into a text file Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
