1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subArray and aSub questions
To: [email protected]
Date: Tue, 18 May 2010 12:23:41 -0500
Hi John,
On Monday 17 May 2010 14:09:54 John Dobbins wrote:
> question 1) does Channel Access transfer only NELM number of values or is
> it transferring MALM number of values?
CA transfers the number of values requested, and will zero-fill any values
beyond the number of elements that the record type reports; caget lets you
limit the request size, but it defaults to the whole array as reported by the
record type's cvt_dbaddr() routine at connection time.
> question 2) would this break down if I attach a monitor to my_subArray?
> i.e. will changing NELM cause problems for a monitor?
No, but IIRC CA currently fixes the amount of data that will be sent at
subscription time; if the client specifies zero for the number of elements it
will be taken as the array size reported by the record type's cvt_dbaddr()
> question 3) does aSub field NEA (number of input A elements) get set by db
> processing when input A is read in? i.e. can my subroutine use the value of
> NEA to tell how many values were read in?
NEA does get updated when the input link is read *provided* that it's a DB
link.  CA links don't know how much data was actually transferred, so NEA will
always be set to NOA in that case, but for DB links the size should be
correctly set afterwards.
> question 4) is my aSub subroutine allowed to change NEVA (number of input A
> elements) (Record Reference manual field summary says "no modify" - or does
> that refer only to via dbPut?)
That summary is only for external access to the field, your subroutine is
allowed to change NEVA.
> question 5a) if answer to 4 is yes, will "caget my_aSub.VALA" return NEVA
> number of elements?
No, it will return NOVA elements, but only the first NEVA will come from VALA,
the remaining elements will be zero.  CA doesn't tell you what value NEVA had
at the time though, and unfortunately monitors do not get posted on the NEVA
field so you'd have to do an explicit ca_get() to find it.
You might be able to utilize the first array element to hold the size if this
is important to you and you have control over the client code that will be
accessing the array.  This is a limitation of the current CA implementation
and API.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
subArray and aSub questions John Dobbins
Prev: Re: compiling SDDS, libpng.a Patrick Thomas
Next: epics debian repository update Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: subArray and aSub questions John Dobbins
Next: busy record Patrick Thomas
