1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epics debian repository update
To: <[email protected]>, <[email protected]>
Date: Wed, 19 May 2010 14:55:26 -0400
Hello Bill,
> One of my bosses (Carlo Segre), who is an official Debian developer,
> had one of my coworkers (Ken McIvor) develop some Debian packages of
> EPICS base for our own use.  He picked a naming scheme like this
> ii  epics                                        3.14.10-1~lenny0
> the Experimental Physics and Industrial Contro
> ii  epics-source3.14                             3.14.10-1~lenny0
> Sources for EPICS
> ii  libepics3.14                                 3.14.10-1~lenny0
> shared libraries used by EPICS clients
> ii  libepics3.14-dbg                             3.14.10-1~lenny0
> debugging symbols for the shared libraries use
> ii  libepics3.14-dev                             3.14.10-1~lenny0
> development files for the EPICS libraries
> ii  medm                                         3.1.3-1~lenny0
> the Motif Editor and Display Manager (MEDM)
> with the version numbers of the packages indicating which version of
> EPICS they were for rather than using the name of the package for
that.
> That is the normal Debian way of handling such things.
This is quite close to what I am doing except I don't have a source
package and am not using backport style (~lenny0) version numbers.
Also, the Base source package has a build dependency on all the RTEMS
stuff, but when I have time I am planning on splitting that into a
separate source package.
> Carlo has said that he would strongly prefer to be a sponsor for
> Michael Davidsaver's packages in the Debian repositories, rather than
> continue to maintain his own versions.  However, for EPICS packages
> to be accepted into the Debian repositories, they must obey Debian
> standards.  In the EPICS case, this mostly affects the naming of
files.
> Thus, in Carlo and Ken's packages for EPICS base, you end up with
> filenames like this:
>     /usr/bin/caget
>     /usr/bin/caput
>     /usr/sbin/caRepeater
>     /usr/include/epics/cadef.h
>     /usr/include/epics/errlog.h
>     /usr/include/epics/tsDefs.h
>     /usr/lib/libCom.so
>     /usr/lib/libca.so
> If you try to get packages accepted into Debian, you will find that
the
> Debian community will not _care_ that EPICS has decades worth of
> history
> in using a different filesystem layout.  They can be quite
intransigent
> about such things.
The practical problem is the EPICS build system, which needs the special
layout.  I had considered unilaterally moving things to the standard
prefix/{bin,include,lib} locations, but was talked out of it.
I wonder if relocating the tree under '/usr/lib/epics/' (like
/usr/lib/gcc/) or '/opt/epics' would be more acceptable?  Though I would
definitely say that the long term solution is making the EPICS build
system more flexible with respect to filesystem layout.
> If you want to see what a Debianized filesystem layout would look
like,
> take a look at Carlo's repository here:
>     http://debian-xray.iit.edu
> Once again, this only includes EPICS base and MEDM.  I have _no_ idea
> what they would do to things like IocCore and SynApps.
The difficultly is cross compiling for RTEMS.  I'm not sure if it will
work out in the long term, but I have had positive feedback from the few
people who have used it.
Michael Davidsaver
NSLSII Controls Group
Brookhaven National Lab
(631) 344-3698
Re: epics debian repository update Benjamin Franksen
Re: epics debian repository update Andrew Johnson
epics debian repository update Davidsaver, Michael
Re: epics debian repository update J. Lewis Muir
Re: epics debian repository update Bill Lavender
Prev: RE: epics debian repository update Davidsaver, Michael
Next: Re: epics debian repository update Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics debian repository update Bill Lavender
