1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Race conditions in SNL programs
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Fri, 21 May 2010 14:40:58 +0200
Hi Ben,
Locking and/or re-reading might be possible for SNL code accessing the variables but what about escaped C-Code? You probably have to take the lock before escaping to C but then nobody is allowed to do blocking things in that code.
A layer of "shadow variables" might be safe. CA updates the shadow copy at any time while the state code executes. Only during the state transition and inside pvGet the data is transfered to the "user copy". (any back inside pvPut). CA has to be locked out only during these copy actions. Of course that requires twice the amount of memory for variables plus some time for the additional copy.
Concerning double: On the new PPC 500v2 core it takes indeed two assembler instructions to load or store a double. Thus doubles are non-atomic.
By the way, I think arrays are already unsafe on the server! If the array record processes and updates the array at the same time as it is sent on the network by CA, the user gets a half old/hald new array. This is because only the pointer to the array is put into the queue for the CA thread, not the array data itself. (I am happy if somebody could prove me wrong.)
Best regards,
Dirk
Benjamin Franksen wrote:
On Friday 21 May 2010, Andrew Johnson wrote:
On Thursday 20 May 2010 17:53:04 Benjamin Franksen wrote:
This bug must have been in the sequencer for a long, long time,
probably right from the beginning.
I'm not convinced it's quite as bad as you think; I suspect it derives
 from R3.14.x when Jeff introduced the ca_enable_preemptive_callback
 option.  Before this time the CA library never got a chance to process
 network messages unless you called it using ca_pend_event() or
 ca_pend_io() so the callbacks would only run when the thread was inside
 the CA library.
Unfortunately, pre-3.14 versions are affected, too, see below.
Hmm, that doesn't necessarily work with multiple state sets though, I
wonder if CA supported sharing CA contexts back then?
It did, this is what the ca_import routine was for.
You are right that if you use one single task and ca_disable_preemptive_callback (or, equivalently, the old ca_task_initialize), then there is no problem. However, even the old 1.9.x sequencer releases use an extra auxiliary task to initialize CA, and a separate task for each state set taht calls ca_import. The auxiliary task is the only place where ca_pend_event is called. This means all callbacks will be executed in the task context of the auxiliary task, and (I checked it) there are no locks taken when the callback copies the data into the program variable.
So, the only difference is that in the old versions it is the sequencer's own task, while in later versions it is a (hidden) CA internal task.
Cheers
Ben
Re: Race conditions in SNL programs Benjamin Franksen
Re: Race conditions in SNL programs Andrew Johnson
Prev: Re: Race conditions in SNL programs Benjamin Franksen
Next: Re: Race conditions in SNL programs Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
