On 05/25/2010 09:55 AM, John Dobbins wrote:
Is it possible to use labCA to retrieve arrays larger than 16K?
Yes - I routinely use that.
You have to make sure EPICS_CA_MAX_ARRAY_BYTES is set
in the environment *before* you start matlab or scilab (RTM).
On the IOC, too, you need EPICS_CA_MAX_ARRAY_BYTES but
since you tested with caget that's obviously set up correctly.
-- Till
I have EPICS_CA_MAX_ARRAY_BYTES set to a large number and verified
that caget will retrieve a large array but labCA 3.1 returns an error.
data= lcaGet('IBLEMS01_data', 120000);
Initializing labCA Release '$Name: labca_3_1 $'...
Author: Till Straumann <[email protected]>
??? Error using ==> lcaGet
multi_ezca_get - ezcaGetWithStatus(): get_callback() : The requested
data transfer is greater than
John Dobbins
Cornell University
Laboratory for Elementary-Particle Physics
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
- labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
RE: labCA and EPICS_CA_MAX_ARRAY_BYTES Allison, Stephanie
Re: RE: PV's element count differs though CA gateway Carl Schumann
<2010>
2025
2026
RE: labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
<2010>
2025
2026
