Is there still a limit on the length of arrays?
I understand that the client and ioc needs to be configured with
EPICS_CA_MAX_ARRAY_BYTES
Note that the number of bytes is not the numbers of values.
16K of double variables is only 1K values....
is this still a limitation in 3.14.11?
E
On 10:27 Tue 25 May , Till Straumann wrote:
> On 05/25/2010 09:55 AM, John Dobbins wrote:
>> Is it possible to use labCA to retrieve arrays larger than 16K?
> Yes - I routinely use that.
> You have to make sure EPICS_CA_MAX_ARRAY_BYTES is set
> in the environment *before* you start matlab or scilab (RTM).
> On the IOC, too, you need EPICS_CA_MAX_ARRAY_BYTES but
> since you tested with caget that's obviously set up correctly.
- RE: labCA and EPICS_CA_MAX_ARRAY_BYTES Mark Rivers
- labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Till Straumann
Re: iPhone port Ralph Lange
Re: running IOC on 80188 processor running DOS Eric Norum
<2010>
2025
2026
<2010>
2025
2026
