1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: labCA and EPICS_CA_MAX_ARRAY_BYTES
To: <[email protected]>, "Till Straumann" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 25 May 2010 17:31:39 -0500
No, there is no limit, just set EPICS_CA_MAX_ARRRAY_BYTES.  We are sending 16MB images over CA with no problem.
Amd 16K of doubles is not 1K values, it is 2K.  A double takes 8 bytes on every architecture I know of.
From: [email protected] on behalf of [email protected]
Sent: Tue 5/25/2010 4:15 PM
To: Till Straumann
Cc: EPICS Tech-Talk
Subject: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES
Is there still a limit on the length of arrays?
I understand that the client and ioc needs to be configured with
Note that the number of bytes is not the numbers of values.
16K of double variables is only 1K values....
is this still a limitation in 3.14.11?
E
On 10:27 Tue 25 May     , Till Straumann wrote:
> On 05/25/2010 09:55 AM, John Dobbins wrote:
>> Is it possible to use labCA to retrieve arrays larger than 16K?
> Yes - I routinely use that.
> You have to make sure EPICS_CA_MAX_ARRAY_BYTES is set
> in the environment *before* you start matlab or scilab (RTM).
> On the IOC, too, you need EPICS_CA_MAX_ARRAY_BYTES but
> since you tested with caget that's obviously set up correctly.
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Till Straumann
labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
Prev: Re: running IOC on 80188 processor running DOS Eric Norum
Next: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
