1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 25 May 2010 18:36:33 -0500
On 05/25/2010 05:31 PM, Mark Rivers wrote:
No, there is no limit, just set EPICS_CA_MAX_ARRRAY_BYTES. We are sending 16MB images over CA with no problem.
Amd 16K of doubles is not 1K values, it is 2K. A double takes 8 bytes on every architecture I know of.
IIRC it can be a little less because the EPICS_CA_MAX_ARRAY_BYTES include the extra info (status, timestamp etc) -- details depend on the DBR type.
In labCA PVs are normally retrieved as DBR_TIME_xxx.
A limitation of the underlying ezca library is that when you fetch
units or limits (stuff that isn't provided with DBR_TIME_xxx) then
ezca uses a DBR_CTRL_xxx with the native element count of the PV
even though the array elements themselves are discarded.
This is unfortunate when you have a slow connection.
E.g., if you call
lcaGetUnits(pv)
and your PV has a large native element count then the entire
array is transferred and discarded (and the call will fail if
your EPICS_CA_MAX_ARRAY_BYTES is too small).
Luckily, if you ever run into that problem you can obviously
work around in most cases by reading the '.EGU' field
lcaGet(pv + '.EGU'); // this is scilab notation
HTH
T.
From: [email protected] on behalf of [email protected]
Sent: Tue 5/25/2010 4:15 PM
To: Till Straumann
Cc: EPICS Tech-Talk
Is there still a limit on the length of arrays?
I understand that the client and ioc needs to be configured with
Note that the number of bytes is not the numbers of values.
16K of double variables is only 1K values....
is this still a limitation in 3.14.11?
E
On 10:27 Tue 25 May , Till Straumann wrote:
On 05/25/2010 09:55 AM, John Dobbins wrote:
Is it possible to use labCA to retrieve arrays larger than 16K?
Yes - I routinely use that.
You have to make sure EPICS_CA_MAX_ARRAY_BYTES is set
in the environment *before* you start matlab or scilab (RTM).
On the IOC, too, you need EPICS_CA_MAX_ARRAY_BYTES but
since you tested with caget that's obviously set up correctly.
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Matt Newville
labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Till Straumann
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
RE: labCA and EPICS_CA_MAX_ARRAY_BYTES Mark Rivers
Prev: RE: labCA and EPICS_CA_MAX_ARRAY_BYTES Mark Rivers
Next: Re: iPhone port Pelaia II, Tom
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Matt Newville
