I think that it would work if you just left off the width -- "%.2f"
On May 26, 2010, at 8:45 AM, Burkhard Kolb wrote:
> Hi Dirk,
> I am just writing protocol files for a Lauda chiller unit (RE 304 and RE 306).
> http://www.lauda.de/hosting/lauda/website_en.nsf/urlnames/kaeltethermostate_produkte
> It requires floats as parameters in a special way:
> Example "OUT SP 00 20.01"
> The parameter here can range from 1 to 3 digits in front and 2 digits behind the
> decimal point.
> If I use %6.2f it will work for "120.01", but will write " 20.01" in case of the
> value "20.01".
> The extra blank will cause the unit to flag the command as error.
> I can use the "-" modifier to get rid of the leading space...
> But then the string sent looks like "20.01 " and the unit will again
> complain. Can I suppress leading and trailing spaces?
> Cheers, Burkhard
> Dr. Burkhard Kolb
> Tel +49 6159 712667
> GSI Helmholtzzentrum für Schwerionenforschung GmbH
> Planckstraße 1 | D-64291 Darmstadt | www.gsi.de
> Gesellschaft mit beschränkter Haftung
> Sitz der Gesellschaft: Darmstadt
> Handelsregister: Amtsgericht Darmstadt, HRB 1528
> Geschäftsführung: Professor Dr. Dr. h.c. Horst Stöcker, Christiane Neumann, Dr. Hartmut Eickhoff
> Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
> Stellvertreter: Ministerialdirigent Dr. Rolf Bernhard
Eric Norum
[email protected]
- Re: stream device formatting question Burkhard Kolb
- stream device formatting question Burkhard Kolb
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Matt Newville
<2010>
2025
2026
<2010>
2025
2026
