1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stream device formatting question
To: Eric Norum <[email protected]>
Cc: tech-talk Mailing List <[email protected]>
Date: Thu, 27 May 2010 10:07:18 +0200
that does the trick.
Best regards,
Burkhard
Am 26.05.2010 um 17:53 schrieb Eric Norum:
> I think that it would work if you just left off the width -- "%.2f"
> On May 26, 2010, at 8:45 AM, Burkhard Kolb wrote:
>> Hi Dirk,
>> I am just writing protocol files for a Lauda chiller unit (RE 304 and RE 306).
>> http://www.lauda.de/hosting/lauda/website_en.nsf/urlnames/kaeltethermostate_produkte
>> It requires floats as parameters in a special way:
>> Example "OUT SP 00 20.01"
>> The parameter here can range from 1 to 3 digits in front and 2 digits behind the
>> decimal point.
>> If I use %6.2f it will work for "120.01", but will write " 20.01" in case of the
>> value "20.01".
>> The extra blank will cause the unit to flag the command as error.
>> I can use the "-" modifier to get rid of the leading space...
>> But then the string sent looks like "20.01 " and the unit will again
>> complain. Can I suppress leading and trailing spaces?
>> Cheers, Burkhard
>> Dr. Burkhard Kolb
>> Tel +49 6159 712667
>> GSI Helmholtzzentrum für Schwerionenforschung GmbH
>> Planckstraße 1 | D-64291 Darmstadt | www.gsi.de
>> Gesellschaft mit beschränkter Haftung
>> Sitz der Gesellschaft: Darmstadt
>> Handelsregister: Amtsgericht Darmstadt, HRB 1528
>> Geschäftsführung: Professor Dr. Dr. h.c. Horst Stöcker, Christiane Neumann, Dr. Hartmut Eickhoff
>> Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
>> Stellvertreter: Ministerialdirigent Dr. Rolf Bernhard
> Eric Norum
> [email protected]
stream device formatting question Burkhard Kolb
Re: stream device formatting question Eric Norum
Prev: Re: labCa 64-bit Till Straumann
Next: Re: PV's element count differs though CA gateway Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: stream device formatting question Eric Norum
Next: Recovering invalid records emmanuel_mayssat
