1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV's element count differs though CA gateway
To: Carl Schumann <[email protected]>
Cc: "'Salah J Chaurize'" <[email protected]>, "'Dehong Zhang'" <[email protected]>, "'Denise S. Finstrom'" <[email protected]>, [email protected]
Date: Thu, 27 May 2010 13:08:34 +0200
Hi Carl
The simple but frustrating fact is: You cannot run anything with dynamic data types or array sizes through the gateway.
This is because CA does not support data type changes yet. This information is only fetched once at connection time. Thus a client must disconnect and reconnect to run with the updated data type. The gateway is a client that keeps the connection for two more hours after the last client disconnected (Though this timeout can be modified with an environment variable).
So at the moment only this approach works:
1. Close ALL clients accessing the waveform. (You must be sure that really every client has disconnected, not only yours.)
2. reboot the IOC
3. Wait for 2 hours
4. restart the client.
If you are not patient enough but have access can restart the gateway:
1. Reboot the IOC
2. Restart the gateway
Sorry about these bad news.
Dirk
Carl Schumann wrote:
It turns out the IOC changes the element count on the PV dynamically, so rebooting would present some issues:
1. The required frequency and determining when one is required.   The element count appears to be the product of two PV's values which may be changed by users at any time.
2. Disruption to other connections.   What does EPICS do if anything to reestablish connections when a machine along the connection is rebooted?
Carl
----- Original Message -----
Date: Friday, May 21, 2010 3:30 pm
Subject: RE: PV's element count differs though CA gateway
To: 'Carl Schumann' <[email protected]>, [email protected], 'Dehong Zhang' <[email protected]>
Cc: 'Salah J Chaurize' <[email protected]>, "'Denise S. Finstrom'" <[email protected]>
Hi Carl,
I suspect that the gateway has been attached to that PV for a long time, and
that it learned a maximum element count when it initially connected which is
no longer accurate. Rebooting the IOC or restarting the gateway, whichever
is easiest, might help. Also, note that services (a waveform record in an
IOC in this case presumably) generally report a maximum element count when
the client connects, but can choose to return a lesser current amount of
elements later as appropriate.
PS: I am out the door on the way to Oxford for the codeathon Saturday
afternoon, and since the rules here say that I can't take my smart card out
of country then I will not have email access for some weeks after that, but
perhaps I will see you at the EPICS meeting.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
-----Original Message-----
[email protected]] On Behalf Of Carl Schumann
Sent: Friday, May 21, 2010 1:15 PM
To: [email protected]; Dehong Zhang
Cc: Salah J Chaurize; Denise S. Finstrom
Subject: PV's element count differs though CA gateway
Tech-talk, Dehong Zhang,
We have a client application which attempts to access a PV's
elements 0
to 999 .   This application is run on two sets of machines.   One set
must go through an EPICS gateway to access the PV.  The other set does
not do so.    The application does not run properly when going through
the gateway because of an out-of-bounds error at element 940.   It is
able to access elements all they way up to 999 without issue when there
is no gateway involved.
We were able to track this issue down to a difference in the element
count reported by the originating IOC vs. the gateway using cainfo.
For the gateway case cainfo reports element count 940, but for the
non-gateway case cainfo reports 1000. Using EPICS_CA_ADDR_LIST we
were able to reproduce both element counts on a single machine depending
on whether the gateway or the originating IOC responded. The
result is
attached.
Me and my co-workers find this result unexpected and are not sure
how to
fix it. Any help would be appreciated please. Thanks for your time.
Sincerely,
Carl Schumann
P.S.: for my co-worker Dehong owner of the hins_ws.py:
The client is hins_ws.py. The PV is PD_LEBT:Inst:WS1.RST1. It is
the
out-of-bound error that prevents the Save Result button from generating
a file.   Do have any insight about what might be going on here?  Thanks.
PV's element count differs though CA gateway Carl Schumann
RE: PV's element count differs though CA gateway Jeff Hill
Re: RE: PV's element count differs though CA gateway Carl Schumann
Prev: Re: stream device formatting question Burkhard Kolb
Next: Epics 3.14.8: faulty registrar statement in dbd causes memPartAlloc error on vxWorks Goetz Pfeiffer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RE: PV's element count differs though CA gateway Carl Schumann
Next: fsmRecord preview Davidsaver, Michael
