1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS wiki is down
To: [email protected]
Date: Fri, 28 May 2010 05:27:58 -0500
On Friday 28 May 2010 05:17:54 I wrote:
> Actually all external accesses to the APS web server are failing at the
> firewall, the website still works fine from the inside.  I am aware of the
> problem but I don't expect any response from IT to fix it until they start
> work, which could be 3 hours from now.
Ok, so it looks like they fixed it already, try forcing a page reload
(Shift+Ctrl+R) or clearing your browser cache if you're still seeing the Proxy
error.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
EPICS wiki is down Benjamin Franksen
Re: EPICS wiki is down Andrew Johnson
Prev: Re: EPICS wiki is down Andrew Johnson
Next: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Fall Epics Meeting location? Jane Richards
