> Through exec() calls a state machine can call any program or script
> written in any language on your system. You find that too low level?!
> Could you explain your definition of high level in that context?
end_stations_protocol:
align sample with beam
detector_acquire_image
move_grid
rotate_sample
move_grid
insert_sample_3
collect_data_set
remove_sample_from_field_of view
send_email_to_experimenter
move_data_files_to_long_term_file_server
each command is drag-and-dropped by the experimenter (not a programmer)
sequence can be changed by the experimenter function of what he wants to do
He should be able to work independently of programmers
synchroton-turn-on:
turn_on_injector_laser
warm_up_modulator_1
condition_magnet
insert_screen_2
start_injector_feedback
Of course, each of those states can be further broken down and later refined
(I can easily see a state machine with 500+ states)
interpreted languages are better, no compilation needed
+ you can program a sequence on the fly (no downtime required)
Can your sequencer to do that?
> I probably am over-interpreting your mails, but I do get the impression
> that you possibly are shopping for interesting solutions while not
> having nailed down your requirements, which IMHO should be done as early
> as possible in the process.
For a software tool like a sequencer, I always consider flexibility ... a requirement.
Emmanuel
- Re: state machine programming Ralph Lange
- state machine programming emmanuel_mayssat
- Re: state machine programming Ben Franksen
- Re: state machine programming emmanuel_mayssat
Re: state machine programming Eric Norum
Re: state machine programming Claude Saunders
<2010>
2025
2026
<2010>
2025
2026
