1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: state machine programming
To: EPICS tech-talk <[email protected]>
Date: Sun, 30 May 2010 23:52:49 -0400
[email protected] wrote:
Through exec() calls a state machine can call any program or script
written in any language on your system. You find that too low level?!
Could you explain your definition of high level in that context?
end_stations_protocol: align sample with beam detector_acquire_image move_grid rotate_sample detector_acquire_image [...] each command is drag-and-dropped by the experimenter (not a programmer) sequence can be changed by the experimenter function of what he wants to do He should be able to work independently of programmers
Of course, each of those states can be further broken down and later refined
(I can easily see a state machine with 500+ states)
interpreted languages are better, no compilation needed + you can program a sequence on the fly (no downtime required)
Ahh... now I can see what you are trying to achieve.
These are not the usual finite state machines, though, and the pluggable parts are not states (as the term is used in EPICS context).
The sequencer is not the right tool to do this, neither probably are the FSM record or the Qt4 thing you were mentioning.
You are looking for a generic script execution engine for an interpreted language, with (possibly) a graphical interface. The trickiest part of these things is getting the exception/error handling right, with the different options of ignoring vs. instant correcting vs. fallback vs. safe state transition. To sucessfully do that, state machine like behavior will be part of the solution, of course.
The closest thing within the EPICS context (that I know of) is the PEM system you mentioned [1], used at the APS for their scripted operation procedures. It almost looks like what you described in your last mail - I don't know implementation details or recent developments, though.
Other places to look would be the high level app frameworks: XAL and GDA might have interfaces that allow such kind of hierarchical script snippeting. Again: I would see the error handling always being the hard-to-get-right and crucial part of these engines.
Good luck!
Ralph
[1] http://www.aps.anl.gov/Accelerator_Systems_Division/Operations_Analysis/manuals/APSPEM/APSPEM4.html
Re: state machine programming Claude Saunders
RE: state machine programming Dalesio, Leo
state machine programming emmanuel_mayssat
Re: state machine programming Ben Franksen
Re: state machine programming emmanuel_mayssat
Re: state machine programming Ralph Lange
Prev: RE: state machine programming Dalesio, Leo
Next: ask for help renliqin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: state machine programming emmanuel_mayssat
Next: Re: state machine programming Claude Saunders
