Title: RE: state machine programming
> end_stations_protocol:
> align sample with beam
> detector_acquire_image
> move_grid
> rotate_sample
> each command is drag-and-dropped by the experimenter (not a programmer)
> sequence can be changed by the experimenter function of what he wants to do
> He should be able to work independently of programmers
> Of course, each of those states can be further broken down and later refined
> (I can easily see a state machine with 500+ states)
> interpreted languages are better, no compilation needed
> + you can program a sequence on the fly (no downtime required)
GDA from Diamond and Daresbury, would be worth a look. This appears to be a standard issue with experimental beam lines. But as you say, the problem is hierarchical. An SNL program may represent some function that is always done the same and has a robust implementation - such as align sample with beam.
The other thing to consider is execution time. Many experiments are moving to on the fly scan - so scripts set up the parameters, but the motion and image acquisition are too fast to be sitting across the network or even on the IOC. We are seeing requirements to set up the motion profile, set the conditions for triggering acquisition, and start the acquisition.
Ralph already mentioned robustness. Scripting tends not to have much on the way of robustness - tests for network outages, verify that outputs were actually set all the way to the hardware, setpoints and outputs stay matched etc...
Is there a good document on PEM? Where is it being used?
Bob
- state machine programming emmanuel_mayssat
- Re: state machine programming Ben Franksen
- Re: state machine programming emmanuel_mayssat
- Re: state machine programming Ralph Lange
Re: state machine programming quock
<2010>
2025
2026
<2010>
2025
2026
