Thanks All for answering.
I did consider using the hardware timer on the mvme6100 board. This would require to use vxWorks specific calls, which I wanted to avoid, as well as other complications.
I went ahead and implemented the functionality I was seeking in external hardware, namely NIM. It seems to be working OK. I might learn how to program the epicsTimer some other time.
Thanks again,
Zen
-----Original Message-----
Sent: Thursday, June 03, 2010 2:48 PM
To: Szalata, Zenon M.
Cc: [email protected]
Subject: Re: epicsTimer
Hi Zen
I seem to recall using some SBC that had programmable auxiliary clock(s)
one could programme to trigger at predefined rate: maybe your h/w has
that capability.
"sysClkRateSet(5000)" from vxWorks, indeed be very cautious !
Matthieu
On 06/03/10 17:35, Ron Sluiter wrote:
> Addressing the limits of the VxWorks system clock....
> With VxWorks 5.5, the upper limit on the system clock is set by the
> SYS_CLK_RATE_MAX parameter in the <WIND_BASE>/target/config/mv<cpubrd>.h
> file. For a MVME5100 board, the default limit is 5000 Hz (200 us). The
> default system clock rate to 60 Hz. You can change the system clock
> (before EPICS iocInit is called and only with EPICS R3.14 and above)
> with a "sysClkRateSet(5000)" call. Of course, setting the system clock
> to 5000 Hz is going to cause a timer interrupt every 200 us and create a
> lot of overhead; use with caution.
> Ron
> Eric Norum wrote:
>> The epicsTimer quantum is that of the vxWorks system clock and is
>> almost certainly too large for this to be accomplished.
>> If you have a hardware timer available you could use it to generate
>> interrupts and perform the timing that way.
>> If you need really precise timing you might have to move all this out
>> to custom hardware.
>> On Jun 3, 2010, at 1:15 PM, Szalata, Zenon M. wrote:
>>> I have a VME system, which is external trigger driven. I wrote a
>>> device driver for one of the modules in the VME crate. The device
>>> driver is so far OSI. I am using EPICS R3.14.11 and vxWorks 6.6.
>>> In my device driver, I need to execute a command a few hundred of
>>> micro seconds after the trigger. The device driver responds to the
>>> trigger, by queuing a call back routine. I would like to setup in the
>>> trigger handling call back routine another call back routine to be
>>> called a few hundred microseconds later. I don't want to call vxWorks
>>> routines directly. Looking through "EPICS: Input/Output Controller
>>> Application Developer's Guide", it seems to me that epicsTimer is a
>>> good candidate. Unfortunately, as it is for me, this guide is very
>>> good once I know what I am doing. Since I have not used epicsTimer
>>> before, the description in the guide is not explicit enough to be
>>> useful.
>>> I would greatly appreciate if someone sent me an example of how to
>>> accomplish my goal in a device driver written in C.
>>> Thank you,
>>> Zen
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- epicsTimer Szalata, Zenon M.
- Re: epicsTimer Eric Norum
- Re: epicsTimer Ron Sluiter
- Re: epicsTimer Matthieu Bec
EPICS supported RGAs Ralph Lange
<2010>
2025
2026
<2010>
2025
2026
