1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: Waveform Record Device Support
To: [email protected], [email protected]
Date: Tue, 8 Jun 2010 10:28:57 -0500 (CDT)
>Thanks for the replies.
clip ...
>As a follow up question, what would be the recommended way of performing
>calculations on array data within the EPICS database?  Do I have to
>resort to subRoutine records?  In my individual channels of data
>(subArray records) I have multiple quartets of data, one for for each
>turn captured, I need to perform calculations on each of these quartets
>to determine beam position for each turn.
You may want to look at this work of using Octave in an IOC by Miroslaw ...
http://www.aps.anl.gov/epics/meetings/2007-04/e138/Octave-iocHamburg.pdf
>Thanks,
>Graham
>-----Original Message-----
>From: [email protected]
>[mailto:[email protected]]
>Sent: 07 June 2010 22:39
>To: Cox, Graham (STFC,DL,EID)
>Cc: [email protected]
>Subject: Re: Waveform Record Device Support
>On 10:06 Mon 07 Jun     , [email protected] wrote:
>> I am integrating a turn-by-turn BPM system into EPICS and would like
>> to store the raw BPM pickup data in a waveform record.  Due to the
>> nature of the system, each run can result in a different number of
>> samples for each BPM pickup, so the array size is unknown in advance
>> and could potentially be different every run.
>Given my limited experience with particle accelerators, I am just
>wondering what kind of system are you working with?
>Storage ring, linac, ... pulsed, not pulsed?
>If the waveform length is changing, it can only be because data
>acquisition is asynchronous.
>Are you sampling CW signals? I can't think of a system that would work
>with those requirements.
>Could you expend?
>> Is it possible to resize the number of waveform record elements in my
>> device support, or do I have to size the waveform record in advance
>> for the maximum number of samples that could be expected.  Most of the
>> examples of waveform device support I see read the nelm field and
>> return this fixed amount of data via the records bptr.
>Another solutions may be to use FIFO waveforms, aka compress records.
>The compress record is part of epics-base.
>In this case, the number of samples per channel acquired can be
>different, but the length of the FIFO stack can be the same.
>Good luck,
>Emmanuel
>Scanned by iCritical.
Prev: Re: Waveform Record Device Support Dirk Zimoch
Next: CSS BOY XY Graph John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Waveform Record Device Support Till Straumann
Next: CSS/Eclipse Introduction from EPICS Meeting Kasemir, Kay
